beachsideev
That never worked for me.Did you try not using AC on COP and using "auto" for your AC?
Probably been said here but I believe using cabin overheat protection with AC makes this problem occur faster. You might want to try cabin overheat without AC, if you're using COP at all...
Air conditioning is air conditioning. What is so different about the AC being used during cabin overheat protection mode?that will help with range too.
I can confirm that smell returned after I used cabin overheat protection with AC After a while when temps reached 119 here in PHX.
Is it too late to try the AC off but fan on trick?
Car is stationary. AC is run with short down periods (which people have reported helps smell happen quickly). Car temperatures are reduced from temps that might help kill or reduce bacteria/fungi populations. Coils don't get a chance to dry off completely.Air conditioning is air conditioning. What is so different about the AC being used during cabin overheat protection mode?
Since you are in the mood, try this oneNothing. All of this stuff is fake solutions. So far all we know is you can spray cleaner in the coil and it will go away for a while.
If you precondition or run the AC before you get in the car you will clear the smell before you get in.
It rained today and sure enough I got the smell back. It's so gross. Now I'm deciding what new cleaner to try or just spray Lysol.
I have the BMW too for 18 years now. Cabin air filter changed 5 years ago. No smell.I don’t have the problem in either of my two Ts and my bud with a 5 year old M3 that never changed his filters has no smell ever.
Crazy as it sounds, think you guys might have a water leak into rhe vehicle. Are we talking only one model? One year? Is either vehicle Model known to have water leaks from rain into some part of the vehicle?
It almost never rains where I live so that theory is shot, plus I park indoors. It's 100% caused by the AC.I don’t have the problem in either of my two Ts and my bud with a 5 year old M3 that never changed his filters has no smell ever.
How about heat pump vs no heat pump?It almost never rains where I live so that theory is shot, plus I park indoors. It's 100% caused by the AC.
It's the condensate from the AC for sure. I just parked the car for 4 days, not using it at all, the car stank a lot last week but when I turned on the AC just now it smells clean, the normal car AC smell.How about heat pump vs no heat pump?
Maybe something is stuck
Ozium 3.5oz Air Sanitizer Spray & Odor Eliminator for Homes, Cars, Offices and More, New Car Smell, (Pack of 2)
definitely not clogged. Water runs out while AC's on, also runs out when I use foam cleaners that condenses.Remember finding water under the vehicle after AC runs
Like at home, drops out the water
What about a clogged drain on rhe Tesla?
I've never had any loaner that didn't smell and/or nasty.I had a loaner M3 in July for 24 hours and it had the stink immediately so I know how bad it is; it was gone after a few minutes and I did not notice it the next day when I returned it to the SC in Devon Pennsylvania.
Does most every M3 have this problem?
Thx Nate.I've never had any loaner that didn't smell and/or nasty.
Cabin air filter needs to be replaced every year at the minimum and clean with spray at every change to prevent the smell. Tesla says every 2 years, but it is for the performance aspect of it, not the smell.
So, I did the test to verify the source of the smell.Thx Nate.
Does your model suffer from air filter stench or have you avoided it altogether with biannual cabin air filter change and spray?
