The parts arrived at the end of last week so I spent the weekend installing them. Just for fun I cut the old one open and it was damp and full of rust.
You'll notice the long sharp needle with a grease fitting on one end. No, I won't be shooting up lithium [grease], although it might help some of my joints on damp days. That's actually the only way to grease the inner toe links (pictured). You don't insert it through the rubber boot by poking a hole in it. You push it in between each rubber seal and the metal. It takes four hands and makes quite a mess.
If you do this it helps to measure your whole tie rod length before you start so you don't have to do a rear alignment when you're done. I measured the distance from each tie rod end to the rod where the jamb nut butts up against it using calipers.
Only one side was bad but my car is handling
much better now. It's especially noticeable on highways or any time you're going fast.
