I use the auto high beams. Sure they may go off and on at times but I don't have to over think using high beams manually. The MX lights are not the best compared to our MY so I'll take any bright light I can get.
Yes but they blind the oncoming traffic which is not a very good thing.I use the auto high beams. Sure they may go off and on at times but I don't have to over think using high beams manually. The MX lights are not the best compared to our MY so I'll take any bright light I can get.
if you hold down the wiper button it will go at the quickest speed while you use voice control to increase wiper speed to max.
If you hold down the wiper button it sprays the windscreen, doesn’t it?
Totally agree about the lights being too slow reverting to high beam. Around 2.5 seconds of blindness. I’m also from rural UK.I have only had my M3P for three weeks and have to agree with all of these who say that both the auto high beams and auto wipers are simply not fit for purpose. They are far worse than any of the similar systems that I have had in competitors' vehicles over the last fifteen years or so.
For example, my 2018 BMW 540i has matrix LED headlights that turn with the front wheels and flawlessly dip only that part of the high beam that would dazzle the driver of a car in front or coming the other way and only do so for precisely the right amount of time. In contrast, the Tesla system dips well before it's necessary and the high beam does not come back on for what seems an age after, say, an oncoming vehicle has passed by. I live in rural England and we have undulating, winding roads, where this behaviour is positively dangerous, especially when the only work around is to constantly pull the stalk back (whilst steering the car!). I just switch the feature off and revert to good old manual operation to avoid the problem.
Not good enough for an allegedly high tech car; I judge by results and don't accept Tesla's excuses (eg., "we use cameras and AI") for not getting right things that others have been doing perfectly for years. Oh and the BMW use cameras too, the difference being that they do it properly!
These kind of deficiencies are a great shame because they tarnish what is otherwise a great car.
With the FSD beta it's pretty good, at least for me. The car gets the high beams off when any approaching car is still way off in the distance, and flips them back on pretty fast after the car passes. My guess is Tesla had to put a lot of work into them for the FSD beta and that new logic will trickle down to all the cars as FSD moves out of the beta phase.Just received my M3 2 days ago and the auto high beams control is horrible. It is late going to high beam and dangerously late going to low just as on coming traffic is about to pass. I have a Honda Civic which has auto high low and works perfectly. I just got rid of a Santa Fe with a similar system and it worked perfectly.
I'm extremely disappointed that Tesla can't fix this problem.It is so bad on this new M3 I can't use it . It is NOT safe!
They have had 5 years to get them working. If it was easy to solve they would have. I have to assume this is basically as good as it is going to get. Consider my hope reserve fully tapped outI understand and agree with the criticisms above. AHB is nearly worthless since it reliably blinds oncoming traffic.
We all know Auto-Pilot and FSD are works-in-progress.
The Auto-Wiper is decent, and as noted trivial to override.
The challenge is Tesla hates additional dedicated single-use sensors. They have a passion to get a general (camera in this case) sensor suite and then re-use it with software for a wide variety of tasks. This does literally reduce the cost of the car by fitting it with fewer sensors (and fewer things to break over time). But it means missing out on the fine-tuned already-up-the-learning-curve dedicated sensor performance.
So we wait and hope that some software guys free up to refine the highbeam activation threshold logic. hope hope hope
1 & 4 are my main gripes. I feel guilty blinding oncoming traffic when using auto high beam as I have never been flashed as much as I am in this car. It simply takes way too long to turn off and contributes to spaztic on/off cycling.The auto high beam are bad because
1) it takes too long to turn off for oncoming traffic
2) turns off for no reason sometimes with just few lights on the side of the road.
3) sometimes takes too long to turn on, on dark roads
4) because it takes so long to turn off and on, it sometimes turns on then off again because the car is already approaching.
The camera will never be as good as an eyeball in determining if the light source is a car or a light bulb on the side of the road from far away. I tried to use the auto high beams but I just can't. Now I just manually turn them on and off like I did in my last car.
