Repeated the trip from yesterday today using range mode. It was colder and was raining lightly when we left but the rain didn't last long and most of the trip was still on dry roads. As you'll note we did a little worse on this trip with a little shorter distance this time. I took a route that matches what EVTripPlanner does so I didn't have to put an extra way point in there to trick it to go the way I wanted. So despite going a little less distance we used a tad more energy. I'm guessing most of that is the heating. Same 70°F cabin temperature the whole way and 400 lbs of carbo.
Average speed from Home to Wallace Falls was 40 mph, Speed multiplier of 0.975 on EVTripPlanner equals this. Average temperature on this trip was 59°F. Trip to Wallace Falls is a drop in elevation of 351 feet (per EVTripPlanner).
Average speed from Wallace Falls to Home was 35 mph, Speed multiplier of 0.85 on EVTripPlanner equals this. Average temperature on this trip was 54°F. Trip from Wallace Falls is a gain in elevation of 289 feet (per EVTripPlanner).
Comparison against EVTripPlanner:
Comparison of deltas between trips and EVTripPlanner
From what I understand EVTripPlanner was usually within 10% for people with S85s. If that's the case then then 85D is still using more energy even in range mode than an S85 based on this testing.
One note on the rated miles. They are taken with range mode off to be consistent regardless of how the driving was done.
Location | Time | Temperature (°F) | Rated Range (miles) | Battery % | Trip Estimated Battery % | Energy Used (kWh) | Efficiency (Wh/mile) | Distance |
Home (Leaving) | 15:07 | 59 | 237 | 88 | 64 | 0 | 0 | 0 |
Wallace Falls State Park (Arrival) | 16:25 | 58 | 187 | 69 | 14.1 | 269 | 52.3 | |
Wallace Falls State Park (Departure) | 18:07 | 56 | 186 | 69 | 44 | 14.1 | 269 | 52.3 |
Home (Arrival) | 19:35 | 51 | 129 | 48 | 29.9 | 288 | 103.7 |
Results from | Distance | Driving Time | Energy Used (kWh) | Energy Used (RM) | Efficiency (Wh/mile) |
Actual to Wallace Falls | 52.3 | 1:18 | 14.1 | 50 | 269 |
EVTripPlanner (85D 19" tires) | 50.6 | 1:16 | 11.2 | 37 | 221 |
EVTripPlanner (85 S/P 19" tires) | 50.6 | 1:16 | 11.8 | 39 | 233 |
Actual from Wallace Falls | 51.4 | 1:28 | 15.8 | 57 | 307 |
EVTripPlanner (85D 19" tires) | 50.5 | 1:28 | 12.3 | 41 | 244 |
EVTripPlanner (85 S/P 19" tires) | 50.5 | 1:28 | 13.0 | 43 | 256 |
Delta between | Distance | Driving Time | Energy Used (kWh) | Energy Used (RM) | Efficiency (Wh/mile) |
Actual to Wallace Falls (No Range Mode) EVTripPlanner (85D 19" tires) | 101% | 115% | 125% | 133% | 123% |
Actual to Wallace Falls (No Range Mode) EvTripPlanner (85 S/P 19" tires) | 101% | 115% | 117% | 126% | 116% |
Actual to Wallance Falls (Range Mode) EVTripPlanner (85D 19" tires) | 103% | 102% | 126% | 135% | 122% |
Actual to Wallace Falls (Range Mode) EVTripPlanner (85 S/P 19" tires) | 103% | 102% | 119% | 135% | 115% |
Actual from Wallace Falls (No Range Mode) EVTripPlanner (85D 19" tires) | 104% | 103% | 137% | 149% | 131% |
Actual from Wallace Falls (No Range Mode) EvTripPlanner (85 S/P 19" tires) | 104% | 103% | 130% | 141% | 124% |
Actual from Wallance Falls (Range Mode) EVTripPlanner (85D 19" tires) | 102% | 100% | 128% | 139% | 126% |
Actual from Wallace Falls (Range Mode) EVTripPlanner (85 S/P 19" tires) | 102% | 100% | 122% | 133% | 120% |
