Just like if you install 4x the amount of 1.5kw chargers, which is what you appear to be advocating for in this thread since the beginning.
Again - same is same. There’s no magic to be had here.
Not sure what you are trying to say.
I'm trying to say your argument, which I interpret as "install lots and lots of level 1 chargers, the electricity is basically free and has little impact on your connection to the grid" is nonsensical.Not sure what you are trying to say.
How do you forget the J1772 adapter??? It's locked to the car until you release it.
Plug comes out, adapter stays on, you throw over the cord holder and you drive away.
There's been quite a few Tesla adapters found on J-1772 cords.
And now that you bring up that it's locked, so is the mobile connector.
But the most important thing to remember, is your original question
"When I've tried to talk to people who would be involved in this sort of decision, they seem to have no understanding of what level 1 means, or why it would be very easy to provide.
How can this be promoted?"
YOUR way of doing it is by your own admissions not working.
So open your mind to solutions that may work.
Yes, if you make an argument for me, then you can make it as absurd as you wish.
Level 1 charging uses very little power, so many of them can be installed without a massive connection to the grid.
The advantage of 120V charging is that the electricity costs are virtually zero.
Your words, boss. “Install many L1 chargers, they’re basically free.”The electricity on an L1 charger would barely be noticeable.
The reality is, adding level 2 chargers will make a big difference to the electric bill. That's why the airport doesn't install them. They let contractors install and operate them. Level 1 chargers would have little impact.
No, this is false.It's much more expensive to add 1,000 level 2 EVSE than level 1 EVSE. The electrical connection would have to support a much higher maximum capacity.
No, this is false.
I have been noticing this thread has been continually muddling two different concepts as if they are the same and flowing back and forth between the two as if they are the same thing.
Level 1 versus Level 2:
This is just the voltage level difference between 120V or 240V. If receptacles were being installed, it's the same wire, and it's about the same price for the breakers and outlets. There's really no cost difference at all between Level 1 or Level 2.
EVSE device or not?
This is where the real discussion and disagreement comes from, and it does have some real pros and cons about cost, reliability, maintenance, availability, etc. Actually providing the EVSE instead of an outlet is an extra few hundred dollars per space, plus eventual equipment damage/replacement, service contracts, etc. But it does give the possibility for the place to meter for the electricity cost.
I have no particular opinion or side in this, but it was getting painful seeing the unrelated issue of Level 1/2 getting mixed up with the EVSE equipment question.
The charging speed is, sure, but that's not cost of installation.In all cases, the level of charging is based on power, not voltage.
Level 1 is 120V, regardless of the amps.Level 1 is conventionally 15 amps, or sometimes 20 amps, so in the ballpark of 1.44 to 1.8 kW.
That's pretty oversimplified. There are whole ranges of products, including plenty that are for 15 or 20A circuits. And again, EVSE products are a separate unrelated topic from the voltage difference of Level 1 or 2.Very few level 2 EVSE are less than 6 kW or 30 amps and ranges up to a 50 amp circuit.
That is also false. I covered that earlier. You use exactly the same wire for 120V or 240V connections. It just has to be the right thickness for the amp level.So level 2 will require heavier wire for each unit.
Yes, demand charge issues can be a real factor. But the higher power may be more useful for the users, so that's a strategy balancing decision depending on the circumstance.But the real cost is the higher capacity of the connection to the grid and the higher operating costs from the demand charges.
It's mostly true that Level 2 charging will require heavier gauge wire since I believe that the lowest amperage, commonly used 240V socket is 30A, whereas the highest amperage 120V socket is 20A. Sure there are outliers such as NEMA 5-50 and 6-15 but when was the last time you saw those outlets?That is also false. I covered that earlier. You use exactly the same wire for 120V or 240V connections. It just has to be the right thickness for the amp level.
Tell that to people in Europe/UK.Level 1 is 120V, regardless of the amps.
Exactly! Level 2 uses higher currents than level 1 and so thicker wire.That is also false. I covered that earlier. You use exactly the same wire for 120V or 240V connections. It just has to be the right thickness for the amp level.
Good for you!And yes, I like the last paragraph.
I often park at the long term parking at an airport. I find level 1 charging would be perfect so I could leave the car, and have it topped off when I return. Level 1 charging uses very little power, so many of them can be installed without a massive connection to the grid.
Sorry, I got confused on the conversation. <Best Emily Latella voice> Nevermind.This isn't really about the outlets. These would be direct wired EVSE.
@Rocky_H: Yeah... I agree with your disagree. Had a major brain fart. TWO hot wires are used with 240V, whereas only 1 is needed with 120V.
There has been a lot of discussion on whether 120V outlets or EVSEs are better (I am in the 120V camp for long term charging - just do not need the extra expense of installing and maintenance of EVSEs in a long-term lot), but let’s get back to your original question. As a business they care about their image and the bottom line. So just make a business case they can understand. Here are a few points:
- Image: Installation of outlets for use by EVs shows the lot owner is a supporter of the EV community!
- Revenue: Having EV outlets will draw in business from EV owners who might park at another lot
- Revenue: They could also add a nominal fee for using the outlets
You're stating this as if it's always true. It's not. Current levels versus voltage levels don't have to be tied together like that. When my friend Don got his first electric car, he used a 240V 20A circuit. When my friend Jeff got his first electric car, he used a 120V 30A circuit. The level 1 circuit was higher amp and so needed thicker more expensive wire. These are real examples. Level 2 isn't always higher amp.Higher current costs more to install. Every level 2 EVSE I've seen is higher current than any 120V outlet I've seen.
There's no point in debating this. Especially since not everyplace even has 120V. Level 1 is lower power than level 2 and lower current, so cheaper install.
Yes. It's not absurd.Are you telling me you've seen 15A, 240V EVSE? I think we are crossing over into absurd points.
No it doesn't always.Exactly! Level 2 uses higher currents than level 1 and so thicker wire.
Ehhhh...I think I know what certification thing you're referring to, which is just not used. It talks about things like direct DC charging over J1772 plug pins, which was never implemented in the industry.I'm not going to continue to debate this issue with you. You started off with the misunderstanding that the definition of level 1 vs. 2 is simply 120V vs. 240V. Until you understand that the charging level is set by the power level and not the voltage, you won't understand anything else that we are discussing.
Right. For a 5-15 versus a 6-15, they use the exact same wire, so same cost.When wired directly, 240V EVSE only needs the two hot wires and a safety ground, while 120V needs the hot, neutral and safety ground. The only real difference is the amp rating, and so the cost.
