If it didn't matter, I wouldn't be asking this question on the forum. Once again, 80 percent of tesla 3 owners, when installing a non-original battery, sooner or later get the error "12v battery must be replaced soon". We have whole forums on this issue, and the only effective solution to this problem - buying and installing 1129182-00-B hankook atlasbx. In Ukraine such sell for 500-700 dollars. Here I am looking for where to buy it cheaper, and necessarily new.
P.S - What kind of 12 volt battery do you use? I see you also have a Tesla 3.
The latest software versions in service mode under the LV battery tab have a button to select battery type installing with an Atlas or a Varta which I believe is available in Europe. This note from the service manual :
"Note
If replacing a Clarios (Varta) 12V battery with an AtlasBX 12V battery, or vice-versa, make sure the vehicle is running software version 2023.32 or newer. Update the vehicle software if necessary; see
Software Update."
Additionally:
CAUTION
Before installing the new 12V battery, make sure that the new battery's Open Circuit Voltage (OCV) is above 12.6V. If the OCV is between 12.4V and 12.6V, recharge the new battery. Any battery below 12.4V must be discarded.
If replacing a Clarios (Varta) 12V battery with an AtlasBX 12V battery, or vice-versa, update the vehicle configuration.
I am unable to locate the Varta part number from the parts manual here in the US but the Varta web site has part numbers depending on model 3 configuration. I also noted 2 distributors in Ukraine.
The major difference I see is the Varta has a lower CCA (around 330) versus the Atlas (625) and this may be the source of errors. I have noted on my own Model 3 periodically the car will do what I call a deep cycle test. It will apply load to the battery to bring it down to a low voltage (I have observed around 12.9-12.8) then recharge. Most likely the change in configuration in service mode changes the duration of the test and (lower CCA shorter test). Again just a guess.
You should have free access to both the parts manual and service manual logging into your Tesla account online (not via the app) which also should have the Varta part number in that part of the world.
I come up with this part number but verify on either the Tesla site or Varta site:
Blue Dynamic 545 156 033
Vehicle software 2023.32 and higher should have this update to change battery type.
To enter service mode on software screen press and hold the model type for about 5 seconds. A pulse will be seen (invisible button) password is service and agree to prompts. In LV menu you will the the LV electrical system and there should be a button to change battery type.
As for vehicle error not using an Atlas I have used an Orielly (US distributor) 51R AGM with no errors. Also a DiehardEV B24L (AGM battery) with no errors. It is very helpful to follow the installation sequence as mentioned to erase messages and reset the system. Open the driver door and right rear passenger door and drop both windows. Leave doors open! Open Frunk. Leave open.
Essentially, remove usb devices, turn off environmental, close the Tesla app so it doesn't communicate (this will keep car awake) select "Power Off" and wait (I suggest about 15 minutes I wait until footwell lights off). Remove 12 volt negative terminal. Go under right rear seat (release tape slide toward left side of car) partially lift seat cushion about 8 inches lift out foam block. rotate gray tap down (this raises pull of battery) and set off to side. car is now depowered and let is site for about 30 minutes to totally de-energize systems. remove 12 volt positive terminal and vent hose and swap batteries. Reverse sequence installing positive terminal of 12 volt, connect main battery by pressing down plug and rotate gray lever-raise back up until it clicks fully up, replace foam block and press seat cushion back down until locks. What about 30 seconds before connection negative terminal on 12V. car reboots. The go into service mode, select LV battery and battery type and let car run sequence. When complete leave service mode by holding red button, then connect USB devices and reopen app. Car will stay awake 6 hours running what I call new battery initiallization. Normal sleep wake after that. You're done.
My DiehardEV B24L is 41Ah and 410CCA. I see other 51R batteries (they fit as well) all exceeding 33Ah usually 41Ah or higher with CCA's 435 or higher. The Varta is a 45Ah 330CCA but again of configured then it should work just fine.
