Seeing some of the threads in the Roadster sub-forums about certain vehicles not working well with specific chargers has me somewhat concerned.
Perhaps Roadster owners can provide some insight.
Ok cool. That allays, somewhat, my concerns about compatibility / reliability.Most of these problems have to do with 3rd party J1772 charger incompatibilities. Apparently, there is enough "slop" in the standard that issues are possible. I have never heard of (or had) a problem charging from the Tesla-approved equipment.
I just installed a NEMA 14-50 240V/50A outlet in my garage. On Tesla's webpage it suggest getting the 14-50. FYI, it cost me $560 in cash to my electrician to install the outlet about 20 feet from the panel.
Question still remains: How do you test the HPWC itself without a vehicle though? Put another way -- How do I avoid having to risk a 2nd visit by the electrician (when the vehicle arrives)?
Jkam, Andrew:
Do the both of you already have 200 amp service to your house? I have a 200 amp overhead line, but the utility meter socket cabinet is only rated at 125 amps. I've had two electricians give me informal estimates of $2,000 to replace the utility meter socket.
Jkam, Andrew:
Yes because that is what you'll find at RV parks/campgrounds if you find yourself needing to charge there.Tesla told me to install a NEMA 14-50. Is that still the best choice for the travel cable?
cinergi:
I forgot to mention that I have a 100 amp main circuit breaker panel off of my 125 amp meter socket. No licensed electrician will connect a NEMA 14-50 outlet without upgrading my meter socket.
Jkam, Andrew:
Just entered into a contract with SolarCity to get a NEMA 14-50 outlet installed in my garage. As my main panel is 100A-capable and is neatly located on the outside of the garage wall where I need the outlet to be, SolarCity deemed it a simple enough install that'd not require a main panel upgrade. The cost is $450. Had I needed a main panel upgrade, it'd have been $2,650!
The whole process was straightforward:
- Sent an email to [email protected] and got a call back from a rep who took down some initial info including about which Model S battery pack I'm going for and estimated car delivery date (I said early November).
- The rep then sent out a simple fill-in-PDF survey that asked some questions about the install location, the main panel and the sub-panel.
- I returned the filled-in survey by email along with pictures of the panels, the 100A breaker switch and the garage itself.
- At a time of my choosing, had a followup call with a specialist who had reviewed the survey and the pictures. We talked about daily commute distances and agreed that a 14-50 rather than an HPWC was good enough or me. The specialist gave me the cost estimates on the phone and followed up with an agreement by email (for an install without upgrading the main panel) that I could e-sign. This agreement had estimated install date ranges that are about 3 weeks out as of today.
