Power trunk retrofit causing car awake
That's me - 2019 Model 3 out of warranty end of Sept 2023, and I had Tesla install the powered trunk retrofit in Oct 2023. I paid $1000 for Tesla to diagnose and replace VCFRONT to try to correct the HVAC issue but am I glad I found this thread! I was going to get Tesla to replace my blower motor but now I'll just sit tight and wait for the software fix. Tesla Toronto never told me my intermittent HVAC issue relates to my powered trunk retrofit.
I don’t know how far you’ll get, but ask them to refund your grand. They went on a fishing expedition at your expense!
Reactions: Electrph
You seem to be less upset about your misfortune than I am. I would be raising hell.
Another update (2024.3.25) and another instance of trunk failing to open. Update was performed with trunk 2 wire cable disconnected. Power cycle fixes the problem. Very annoying
I am experiencing the same thing right now. How did you power cycle it? I sat in the car touching nothing for 4+ mins after tapping the power off button under Safety tab, but it didn’t help
I'm guessing "power cycle" as in a soft reboot by holding down the steering wheel scroll wheels down simultaneously until the screen goes black...
I looked it up and followed Tesla's instructions here, but it didn't work, or maybe I didn't do it long enough. Then I left the car sleeping for 6+ hours at work and came back to a working trunk again. "Sorted itself out" kind of fix.
I suppose the person you linked who got it fixed by charging to 80% had left sentry off and gotten the car to sleep after finishing charging, too. It might also just need an hour of sleep, I'm not sure.
It works after a few hours of sleep, but the sleep only happens with the cable disconnected.
I can confirm that power cycle (Safety --> Power Off) with and without the cable connected did not resolve the issue. Disconnecting HV and 12V with and without connector disconnected did not help.
Wonder if something got pushed down as I was on the phone with Tesla support, and they acknowledged they were seeing reports of the issues.
I can also confirm that the cable connected it is still not sleeping.
What a cluster!
Malaromane, thank you so much for making me aware of this thread. I was only reading that other thread that wasn't of any help and has already gone dead. I unplugged that 2-wire connector like you all suggested and I've had no PCS_a022 errors since then (it's been about 24 hours). Also, my car is able to sleep for the first time in 3 months. Totally regret getting that power trunk mod from Tesla. 2019 Tesla Model 3 (firmware 2024.3.25).
