lolachampcar
Essex is my go to. They’ve done bells for my lotus and chevron. Good folks.
What happened to round one? Did you ever get the RB 2466 rotors?Ok
Round two using rotors I am much more familiar with.
AP Racing CP3908-102GA and -103GA
Bobbin hardware is easy to source.
Time to fire up SolidWorks and do some hats
I kinda cocked it up by posting their proprietary information.What happened to round one? Did you ever get the RB 2466 rotors?
Bummer. Though I don’t see the issue with ordering the 2466 parts from racingbrake.com directly.. if I had my Plaid I would certainly be willing to try that! (looks like it might be at least another month for me, unless I’m willing to pay for 21” wheels).I kinda cocked it up by posting their proprietary information.
I would prefer to use some less than top secret standard AP Racing parts that I've used in the past and just make some 7075 bells. The AP bobbins are fairly easy to design for and I have all the dimensions I need from the last inspection.
Thanks for sharing! Yep, need better brakes fo'sho'.
Ok
Jack mode or the air bags completely deflate and the car settles on the bump stops (front in my case) making it a pain to get the jack out. As always, I place a piece of wood or very firm rubber on the rubber jack pad on the car then place the jack under my protective bit.For those of you have have jacked up your S, any tips or tricks?
Are you asking about the front fenders? If so, i don’t think the extra 5mm poke will be a problem.will it clear the fender when doing a cheetah launch?
I tried 305/30-20 but the willtheyfit.com calculator shows a significantly smaller circumference.Are you sure about 305/35/20? Everywhere I have seen says to run 305/30/20.
Genuinely curious as I plan to run the same width on 20s (but 285/35/20 for front)
I’ll have 10” for front and 11” for back. Trying to do the same setup that got leaked for the Plaid track package with the 20” zero-g wheels.I tried 305/30-20 but the willtheyfit.com calculator shows a significantly smaller circumference.
Will you run 285/30-20 on 20x9.5 rims? Isn’t that too wide a tire for that rim width?
