Your complaint should be why is the RWD exceeding EPA rating. Not that your Performance is not meeting it. Elon was smart how he spec’d The cars.
20” wheels, cool weather, driving 75+ mph. 327 wh/mi sounds about right.
>> yea, tire was 40 psi cold. Now 44 getting 300 wh/mi ... I need to check on all.
That’s about 23% below EPA rating. I don’t think EPA tested 20” tires because it was an option when tested.
>> How did you calculate % below? EPA is 310 miles, battery is 75kWh, that gives 240 Wh/mi, not? I am doing some math wrong, please correct me. Even though I come from Financial/Banking industry we do make mistakes.
You’ll probably be closer to EPA rating when it warms up.
>> That's what I suspect, gotta wait closer to summer, tires worn out, probably around 5,000 miles if I can get what our friend in Diamond Bar is getting 280 miles, I'm more than fine with it. But 200-220 miles won't cut it, sorry, again Love Tesla, Elon, Spacex, but don't mess with my pocket.
BTW if your temperture is on 68F (AC on or not) and it’s less than 68F outdoors, your heat is ON.
>> Yes, hence I turned off now and will check on that. But I can't control BMS and we can't access that data... which I think plays a big part.. will be checking battery SOC before leaving the car outside.
Your claim of 130 wh/mi on RWD is exceeding EPA rating by 93%. That’s a bit hard to believe for lifetime of 10,000 miles. Guess they accidentally put in a 2020 Roadster battery in it.
