Johan
Ex got M3 in the divorce, waiting for EU Model Y!
You have a FLIR camera? In that case you are making this way more complicated than it needs to be. Rent an hour of AWD dyno time, run the cars in cruise control at the same speed for x minutes. Use the FLIR camera to check the temperature of all electronics and moving parts. You can roughly integrate temperature over volume to get a comparison of wasted energy.
100Wh/mi WILL show up somewhere, it's a massive amount of heat. If it's in the tires, then the tires will be hot, etc.
edit - you will know EXACTLY where the extra energy is going, whether it be in the inverter(s), battery, motors, tires, bearings, transmission, etc. At 65mph on a dyno that's 6.5kW of heat being dissipated. Hell you could probably do it by feel alone.
You're mirroring my thougts exactly, here's what I posted in Elon Musk tweets software upgrade will increase P85D range - Page 10
So anyone care to guess where those extra 50-100 Wh/mile (compared to a RWD Model S) are going (3,25 to 6,5 kWh per hour of going 65 mph)??? We know they're not going towards propelling the car. Also, we know the added weight creates only slightly increased friction, nothing near 50-100 Wh/mile.
Well... Energy "wasted" i.e. not used to propel the car, must come out as heat somewhere. If a FLIR showed the rear motor as being substantially hotter as compared to the rear motor in a P85 (they should be very similar in set up) after an identical drive then it might suggest that in fact the front and rear motors are counteracting somehow?
Would be very interesting to see FLIRs after a dyno run.
