I had to pry my 910 pads out with a flat head screwdriver to get the adhesive to release, so it seems to hold even after being heated up quite a bit. Not sure how it will hold up to being released and re-adhered though.
The adhesive is only intended for once or twice use, not meant for multiple releases. The particular 3M adhesive is only available to commercial/industrial customers, not consumers, I talked with 3M. The adhesive is there to provide a clean release of pad from rotor when brake isn’t applied, the beefy ears on the pad keeps on the caliper. After couple switches, I ran the pads without anything(most aftermarket pads), it’s fine, no adverse sound or performance hit.
