Thanks, Mark!
At least I know it's not a problem on my end. Will test with the new version as soon as it is available.
Update: I just downloaded v. 1.6.5, and am once again able to change PARAMETER values.
Great to hear.
Regards, Mark.
Thanks, Mark!
Swipe down from the top to see all iphone notifications. The most recent should be listed on that screen somewhere, along with recent emails, missed calls, and text messages. I think the number of items displayed can be configured in the notification settings.Is it possible to see a history of the push notifications on the iphone?
That's exactly, what I was looking for. Thanks
One can setup the depth of the history in the settings. Max number is 10, unfortunately all these stupid door ajar messages erased the meager I was looking for
You can also set it up to send you text messages. That will queue up messages better (the door ajar messages aren't sent there).
Or turn off the door ajar (and other alert) messages.
How exactly do you do that? I get a bunch of door ajar and Wear warning (after changing to winter tires) both as push and sms, a bit anoying.
Set feature #14 to 8.
If ACC is enabled at a location, it will take over the charging. For example, if SOC limit is 90%, SOC is 91%, and you try to manually charge, acc will stop the charge.
Disabling acc for the location should be immediate. But, you should do that before plugging in (or unplug, disable, plug back in).
Vger,
We had an issue several years ago where you could issue the command to start the charge when the car wasn't plugged in. That would put the car in a strange state where it thought it was charging. The workaround was to open and close the charge port door. The OVMS firmware itself was changed a few years ago, to add a validation check that pilot was present before sending the charge start command.
That is the only thing I've heard similar to your problem.
In general, OVMS just acts as a remote VDS. It simply sends the same commands that the VDS does. The top-up button on the VDS is the same function/command as start charge from OVMS.
If the charge port light was white, then it lost the pilot signal. You'd need to slide the connector back to reestablish communications.I'm not certain the issues with OVMS starting charging are worked out. I just had a bad experience with that. Monday morning I woke around 4a.m. and thought... I'm going to be doing a long drive tomorrow. I should do a range charge because it's been a couple months since I have. So I picked up my phone and saw my car was plugged in and standard charged to full. So I changed to range mode and set 32A, then pressed the charge slider and I got the error that the car's charge port was closed, even though it was not. Going to the car screen it showed the charge port as white but earlier that night the standard charge had finished. I've noticed that changing the charge mode causes the app to report strange stuff for awhile. But in this case it was stuck not showing that the car was connected to the charger. I took the app to the settings/control screen to 'reset OVMS Module' and that took awhile but the app still would not recognize that the car was plugged in. I gave up and went back to sleep. Waking hours later the app was still not showing the car plugged in.
Versions are... (oh there is another bug... the vehicle info screen shows... Server 2.6.5/TR/V1 Car 2.6.5/TR/V1 App 3.2.2 (20140628) and it's android. I know the server and car versions are different but sometimes they show the same.)
