Dan5
My logic is that charging an EV is more efficient than pumping water and using that energy for later use.
It becomes more apparent when there is a large discrepancy between EV charge efficiency and water generation/pumping efficiency
Just making up numbers here to illustrate the point.
The baseload has to run regardless, so the emission is the emissions, it doesn't matter of it's an EV, a light, or water pumping, or the electrity dumped into the ground.
Let's say you send 50 kwhr to an EV, and the EV takes 40 kwhr (hypothetical other 10 kwhr lost to chargering, transmission, etc, etc).
If I send that same 50 kwhr to water storage and then output it, and let's say you get 12.5 kwhr out when all is said and done.
Now let's say the emissions is 50 kg of CO2.
The 50 kwhr to charge an EV would have the same impact as 12.5 kwhr of emissions.
The 12.5 kwhr would have been met by water, but it is now met by NG, coal, and other peak sources.
So for that 50 kg of CO2, you either have 40 kwhr (EV charging) or 12.5 kwhr (water pumping) or 0 (electricity gets dumped)
now switch to daytime, the EV used the 12.5 kwhr that would have been used for water pumping so you need to make it.
coal->12.5 kwhr *1010 grams/kwhr= 12.6 kg
NG -> 12.5 kwhr* 465 g/kwhr = 5.8 kg
So instead of having 50 kg of CO2 to create the 12.5 kwhr, you have between 5.8-12.6 kg Co2.
- - - Updated - - -
Or the other way to think of it is I need to eventually have 40 kwhr of power.
Which would give me the lowest emissions?
40 kwhr @ 50 kg
or
12.5 kwhr @ 50 kg + 37.5 kwhr @ 21.6375 kg (grid average)
In reality that 50 kg is a phantom value since it has to be there regardless if an EV is plugged in, running a pump, or if there was no demand
- - - Updated - - -
40 kwhr @ 50 kg
or
