In all fairness, NHTSA will have access to data fields that are redacted from the public. And, when they decide to do an investigation and engineering analysis, they should be able to get more data for individual crashes.Again, you are making stuff up again, that you can't tell from the data. You don't know if the driver was abusing AP or was using FSDb as intended because the data is completely worthless.
How worthless? Take this example: You are exiting the freeway and disable AP, you proceed down the off-ramp and go through a green light and are hit by a driver running a red light 29 seconds after you had disengaged AP. That would be included in the NHTSA report even though AP was not engaged at the time and was no way involved in the collision. You are classifying that as abuse because it happened in an intersection. But there was no abuse, the driver was using AP appropriately.
NHTSA has made sure that the data is complete garbage. I can't think of any valid use for it.
All you can do is make assumptions and jump to conclusions that aren't supported by the data.
- You don't know if the driver was using AP or FSDb.
- You can't determine if the usage was appropriate or abuse of AP.
- You don't know if AP, or FSDb, was in use at the time of the collision. (Or just before it.)
- You don't even know if the ADAS was involved.
- You don't know who was at fault.
- Again, you don't even know if the ADAS was even involved.
- You don't have complete information from most OEMs.
- You can't make any valid comparisons between OEMs.
I have no issue with their conclusions, since they do have access to better data. And, if there are things that can be done to make ADAS functions better, then, by all means, we should find ways to do them.
I would like to see Tesla include traffic light and stop sign control added to basic AP so that it's safer on secondary roads. This is something that AP does for those with EAP or FSD, so it would be a simple addition that might fall under Elon's moral imperative. IT seems silly that TACC and AP will stop if there's a car in front of you that is also stopping, but doesn't stop on its own.
