Hello all,
i'm planning to get model Y and i test drive it 2 weeks ago, i like it and now my plan is does it possible to setup the charging outlet (NEMA 14-50) in my garage.
my breaker is 100AMP, i checked all label as follow: electric stove(40AMP) , dryer(30AMP) , AC(30AMP). I contacted with the management and it is not allow upgarde to 200amp.
i contacted one of the electrician he recommend to setup 40amp 14-50 outlet for the car charger in garage.
My question is it will overloaded the breaker if i turn on all at once? for example. i cooking with stove and turn on the dryer, at the mean time the AC kick in while i charging the car at evening?
My friend (model X owner) recommended plug in the charger and setup the charging time / turn on the charging while you go sleep, so nothing is running at the same time. Can i do it on the mobile app? the way to enter the garage is outside of my house, i don't want to running to plug in the charger in the winter time (possible -40'C here in canada).
can anyone share your charging experience if you can't update to 200amp?
Thank you
PS: my breaker is located inside the house
Thank you
