No gearing required.
Makes more sense to drive the gearing down, thus giving the engine more top speed. This isn't an ICE, and there is more than plenty of torque available from rest. To compensate for the lost acceleration the manufacturers will just increase the engines output, cooling is a non issue if you design them right. In industrial applications there are engine running at the near MW level continuously for years on end without problems. As the batteries get larger capacities, we can afford drain higher and higher currents from them without the risking damage to the battery. The P85D for example, is most likely limited to it's acceleration by it's battery, not the electric motors.
Thus future battery development will offset the need for a gearbox. It's just not needed.
Also remember that the engines are more efficient at higher loads, so this would also aid the range, both at low and high speeds.
