. I have read that Tesla do not like frequent Supercharger use.
The front motor whine is noticeable, especially when accelerating fast. However at cruising speeds on hwy and even around town I cannot hear it at all. Make sure range mode is off. The front motor is utilized more at cruising speeds when range mode is on which might be why you're hearing it more. I'm going to take my work commute with range mode on next week to see if there is a noticeable difference in noise.
Hi,
I just got my car. I am fine with accelaration sound. But I also hear that sound while driving at constant 30 mph, in the city. is it normal?
For those that are complaining about the whine, what do you expect? There are electric motors turning at thousands revolution per minute to move your car, mechanical parts moving, and you expect it to be completely silent??
Well, although I don't mind the slight whine, I also have a Chevy Volt and even at full throttle, it *is* completely silent. Of course, Volt full throttle and S full throttle are two entirely different things..
Perhaps not confirmed, but the noise from the front motor increases substantially whenever range mode is enabled. There also seems to be a spike in front motor noise (shift in noise bias from rear to front) around the 40mph range with range mode off, which then transitions back at higher speeds I think. Anyway, the noise that the OP is mentioning is likely the normal motor noise that all Teslas (both AWD and RWD) make.This is still not confirmed on whether or not front motor bias is affected by range mode.
I think that's purely because the front motor is used more often in Range Mode.Perhaps not confirmed, but the noise from the front motor increases substantially whenever range mode is enabled.
Very helpful list of sounds - thanks for posting TaoJones!There are many noises - some normal, and at least 14 that are abnormal. I know this because I had #14 from the abnormal list for 3 months or more until combining the fix for that (drive unit replacement #1) with recent annual service. For planning purposes, they quoted 8 hours for the annual service and 6 hours for the drive unit replacement, and evidently the expectation is that these are done sequentially - not concurrently - so should you be in the same boat, be prepared to drop off your car early on Day 1 and to retrieve it on Day 3.
You'll find a list here: Sounds of Tesla Vehicles | TeslaTap
