Model S Refresh Mud/Splash Guards
Final Tesla OEM flap update. I cut exactly 1” off the bottom of the flaps before going on a spirited drive in the mountains. They STILL scrape badly with suspension on low and sport mode just in hard cornering. This is nuts and There is no way elon tested these before shipping.
Final Tesla flap update. I cut exactly 1” off the bottom of the flaps before going on a spirited drive in the mountains. They STILL scrape badly with suspension on low and sport mode just in hard cornering. This is nuts and There is no way elon tested these before shipping.
I doubt Elon personally tests anything like this... I would agree that no one at Tesla tested these. Sounds like they are real crap.
@WilliamG
Doesn't really seem to hurt anything. The bottom of the flaps are flexible so it's not like they're going to catch on something and damage the car or pull the flap off.
Reactions: Laddcruzer
Yours do not touch the ground like the Tesla‘s - right? At least in pics it seems like they would not. :)
Highest setting:
Front:
Rear:
Lowest setting:
Front:
Rear:
I made a thread about the OEM flaps so we don't derail M4H4X's post OEM Tesla Model S Refresh Flaps
Well this thread is called "Model S Refresh Mud/Splash Guards", and is not devoted to M4H4X's posts, as useful as they have been. So I'm not sure a separate thread is appropriate. There may be other offerings in the future from other vendors, and I, for one, would like to see those discussions here.
Reactions: bllydia
See attached for OEM Tesla flaps on low suspension setting. Note that the pic on the car, that is after they were very significantly scraped up in the mountains. I also included a measurement of the piece I cut off before the mountain run
Reactions: WilliamG
That measurement is AFTER you cut it? Jeeeez. What was Tesla thinking?
I cut that 1" piece off before I left the neighborhood. Went on a couple hour mountain sprint, scraping in every corner wondering if it will rip off the fender liner or rocker, got home, then measured the mud flap height. That mud flap height is effectively the lean angle of the car at full power through a turn on low & sport suspension setting. It ground off I would guess close to an inch of material, you can see the stringy leftovers across the entire length.
In other words, cutting off 1" wasn't even nearly enough. I would guess you would need to cut off 2-2.5" from the bottom of the OEM Tesla flap for it to be usable.
Reactions: WilliamG
Wow….
That's completely bananas. I fail to understand how these made it out of the testing phase! Did Tesla even bother to drive with these on, or just go with a guess for what size they should be and then go, "F it, good enough!"
@WilliamG Same way the Plaid made it out of the testing phase…. “The delusional people will buy anything Elon sells…” - Tesla Marketing department.
Reactions: WilliamG
