Cottonwood
Roadster#433, Model S#S37
I would step back from this issue and ask yourself if you really need to squeeze that last little bit of charging performance out of your system. On average, how far do you drive and what is your minimum needed charge time? At best, it will save you a bit more than an hour for a zero to full charge (67 minutes - 4:27 vs 5:34). Since you probably won't drive your battery to empty, the actual time difference will be quite a bit less.
I agree completely. The only place this might be justified is at a public High Amp L2 (HAL2) charger where people are worried about charge time on a trip away from Superchargers. I looked into this because the host of the 70A J1772 Charger that I have helped get installed in Salida, CO, Wood's Distillery may change from 240-Volt, single-phase power to 208 Volt, 3-Phase power as their power needs grow.
