Just booked my 2021 M3 in for a service appointment as the ducting around the windscreen had come loose, seems the clip has broken and no longer sits flush, so when the Frunk opens it pushes it out. of position once again.
However, I've just had a quote back (For £0 mind) which is listing a replacement of all 3 PT Sensors labeled 'Model 3/Y Heat Pump PT Sensor Replacement (P2)' but nothing for the windscreen trim.
Seems that Tesla is replacing the Heat Pump Sensors at the same time? Un-sure why.
