Lights on the steering wheel buttons stopped working
22MYP The lights on the steering wheel buttons stopped working. I checked the menu, and they are turned on. Have turned them off and on to see if it helped and it did not. Are there bulbs in the steering wheel that need to be changed? Can I change them?
I also have a 23MXLR and the steering wheel button lights flicker all the time.
Thanks,
Thanks,
There are lights on the steering wheel?
Reactions: EVer Hopeful
Upvote 0
Thanks,
They only come on when the headlights are on. There is no bulb to change. Everything is LED.
Upvote 0
Then what led do I need to replace to make them work? Do you have a part number?
Probably need to replace the panel with the scrollwheels on it, which has the arrows with the embedded lights.
Upvote 0
