Nick, you are a Leaf owner, so you haven't used 75A/80A charging, it moves right along.
Actually, I am a Fit EV owner, and my wife has a Volt.
Proportionally speaking, I do charge at around that speed, thank you very much. I'm just not blessed with an 85 kW-hr battery. Getting 140 MPGe does, however, make up for it.
If he expects to use a J-1772 with a J-1772 to Roadster adapter on one output, and a Tesla 80A Model S connector on the other output, to be worth spending the money on the contactors , sequential mode would be nice, plug in both vehicles and they charge in sequence. To do that, the AC wiring needs to be rated for 80A, requiring a 100A breaker and hard wired with #3 THHN copper.
Fine with me. The Hydra logic board is just fine with that if you can find the wire. It's really easy to find the wherewithal to do 60A per car - that's all I'm saying. And that's 75% of 80A for, oh, conservatively, half the money.
But who am I to judge?
Might have to use 1 GFI coil per AC conductor and a circuit to subtract them from each other (should balance to zero). The wiring will be the challenge on the dual high power hydra, but there are junctions and connectors made for this.
I would modify my 75A OpenEVSE with 2 contactors / cables but I only have 1 EV, the dual charger Model S. I'd do it to prove it could be done, if some one could actually use it when completed.
I am not an expert with current transformers. Naively, I'd say you could connect two in series and run a conductor through each, but you'd need to know for sure that both CTs were wound the same direction, I believe.
In any event, it isn't something I've tried.
