I'm new to EV cars. My first two uses of the SuperChargers is super slow. Normal?
Was there someone plugged into the paired charger?I'm new to EV cars. My first two uses of the SuperChargers is super slow. Normal?
Sounds normal for an older 85kwh pack vehicle! Tesla has intentionally capped the supercharging rate so your battery does not fail within warranty period because they do not want to pay to replace it.In both cases I had driven an hour to get to the station. It's not cold here at 55F. I made sure I was several cars away from the other cars charging as well because I had read about the pairing at one point.
Supercharger pedestals are not always sequential. Have to look at the numbers. Each number has an A & B that are shared.In both cases I had driven an hour to get to the station. It's not cold here at 55F. I made sure I was several cars away from the other cars charging as well because I had read about the pairing at one point.
I have 2013, they throttled charging back on old cars. Many different theories. A class action lawsuit is in action now.
It takes me 2 extra hours now to go to DC, 700 miles. Used to start at over 120kw. Then 110, now 70 or less. I keep a very detailed log book. Pick any theory you like. I like the one that says slow rate to get us out of warranty.
Now that I think about it, 36 kW is the magic number you would get if you were in a stall that is paired with someone charging at a high rate. The minimum you will get is 36 kW and it can go up in steps of 12 kW although I don't always see every step.
Being several spots away doesn’t matter. It matters about the number on the supercharger pedestal. Not always are they 1a/1b side by side. Some are 1a,2a,3a,4a,1b,2b,3b,4b.In both cases I had driven an hour to get to the station. It's not cold here at 55F. I made sure I was several cars away from the other cars charging as well because I had read about the pairing at one point.
36 kw definitely suggests being paired up, as the paired capacity switches in banks of 36 kw. Which also means only when the other car tapers below 72kw would your speed jump up suddenly to around 72 kw.
My 2018 100D seems to be charging much more slowly. Arrived, after 150km drive with supercharger set as navigation destination, with about 30% charge. Charge rate briefly riser to 110kW but then dropped quickly to <90, then at about 50%, <60kW
so I don’t know if the battery is cold, or software is different or what. Last summer I regularly got 140+ kW.
I’m going to hope it is just winter (about 6 Celsius)
