This is your first mistake. The internal pressure when the gauge reads 42 PSI is 57 PSIA. Where the tire is in contact with the air there is a force of 57 pounds on each square inch of the inside with a force if 15 lbs on the outside for a net of 42 pounds termed 42 PSIG with the G standing for "gauge" because that's what a gauge would measure. There is no air under the patch so the only force countering the air pressure from the outside of the patch is 1/4 the weight of the car divided by the patch area.I'm not wrong. Let's do a quick math:
MX weight = ~6000lbs
Tire pressure = 42PSI. This pressure is the EXACT pressure being exerted onto the floor (plus a small amount to account for the weight of the tire itself).
6,000pounds / 57 pounds per square inch = 105.25 square inches of contact. That means the 6000lbs is spread over 105.25 square inches at a pressure of 57 pounds per square inch. In other words, the tires will deform at 57 PSIA (42 PSIG) to make contact with the floor with a total surface area of contact of 105.25 square inches.6,000pounds / 42 pounds per square inch = 142 square inches of contact. That means the 6000lbs is spread over 142 square inches at a pressure of 42 pounds per square inch. In other words, the tires will deform at 42 PSI to make contact with the floor with a total surface area of contact of 142 square inches.
But the area of contact will be less that that because the upward force on the car is the sum of the patch force plus the sidewall load. Following the original line of reasoning here if we remove the Schraeder valve the tyre pressure goes to 0 psig and the patch area would have to go to infinity to keep the car from sinking into the earth. But we know that doesn't happen. As the air escapes the tyre the patch size does increase somewhat but the load no longer carried by the air pressure is assumed by the sidewalls (and, eventually, the rim). The sidewalls are, thus, clearly carrying some of the load. This means that the patch size is even smaller than the 105 square inches. So it appears that the patch size may be about 25 in^2 per tyre. My tyres are 7" wide. If that full width is part of the patch then the patch length would have to be about 3.6" long. Is that how long it actually is? Well, yes, it's about that long but to be honest about it I don't have much confidence in the measurement.
To summarize, you are wrong with respect to two factors:
1)Failure to appreciate the difference between PSIG and PSIA
2)Failure to allow for the part of the load taken by the tire sidewalls.
If you don't believe what I say is true, please read the entry below:
Ground pressure - Wikipedia
"The ground pressure for a pneumatic tire is roughly equal to its inflation pressure."
Roughly because there's the weight of the tire as well.
Forget all the math that was used to prove the point. If the tire is inflated to 42 PSI, the ground pressure is also ~42PSI. It does not matter what the weight of the vehicle is, because the tire will flatten out (until it structurally can't) to support it at the same PSI.
Then you are going to have to take into account the characteristics of the material, since it is the material and NOT the air that is supporting the weight of the vehicleHow about a stiff wall run flat tire no air pressure?
Refuting your refutation: The tire surface under the patch is subject to no pressure from the air as it in not in contact with the air.1) Refuting your contention that I failed to account for PSIG/PSIA:
So now let's refute this refutation with the following gedanken experiment: Take a hollow cylinder and cap it at both ends. Drill into the side of the cylinder, tap it and install a valve and pressure gauge. Using the valve pressurize the cylinder to 50 psig. Set it on its end on a rigid surface. Now put a heavy weight on the top cap and read the pressure gauge. What happens? Well depending on the elasticity of the cylinder material it may go up a fair amount or very little. Were the cylinder steel it would not go up noticeably as the entire load would be taken up by the steel. It would compress but a wee bit so that the length and thus volume of the cylinder would not change much at all and the air pressure, nRT/V, wouldn't change appreciably. But now suppose the cylinder be made of rubber. It is much more elastic and would, under the top load, compress considerably more than the steel one. The volume would become smaller and the pressure go up noticeably. Thus, we see, or should be able to see, that the forces holding the weight up are shared between the air column and the wall material depending on their relative moduli of elasticity. For some reason you think that the wall carries no load - that it is all carried by the air column.1) Refuting your contention that I failed to account for PSIG/PSIA:2) Refuting failure to account for the load taken by the sidewalls:
The load (aka weight of the vehicle) is NOT taken at all by the sidewalls.
Well yes, the contact area supports 100% of the load but only part of the load is transmitted to the contact area by the air column. The rest (or in the case of an evacuated experimental cylinder or tyre all of it) is transmitted through the mechanical structure of the container which, in the case of the tyre, is the sidewall.The load is directed straight down 100% to the contact area. In other words, the contact area is supporting 100% the weight of the vehicle.
That's exactly what I am saying. For example lets say 5400 lbs are supported by the air column and 600 by the sidewalls (I have no idea if those are reasonable proportions). It's apparent you aren't familiar with how these calculations are done but the usual starting point is a "free body" diagram. This isolates a part of the system from the entirety and then the forces acting on this piece are evaluated. At equilibrium the vector sum of these forces is 0. The free body here would be a piece of the the tyre with the dimensions of the patch. The entirety of the vertical forces on this free body are:If you're saying the sidewall is somehow taking on a load, the 6000lb vehicle would no longer weigh 6000lbs.
I think maybe you are beginning to get the idea. You have a couple of structures sharing the load. One is the air column and the other is the rubber of the tyre. How the load is shared depends on the elasticities of the materials and, of course, the geometries.Then you are going to have to take into account the characteristics of the material, since it is the material and NOT the air that is supporting the weight of the vehicle
No, I'm not beginning to get any idea. We are talking about pneumatic tires with air in it and how air is supporting the weight in its entirety, 100%. The run-flat tire example is entirely different, as it is not supported by air but by the tire material 100%. Entirely different animals.I think maybe you are beginning to get the idea. You have a couple of structures sharing the load. One is the air column and the other is the rubber of the tyre. How the load is shared depends on the elasticities of the materials and, of course, the geometries.
I was pretty sure you wouldn't be able to but we are always hopeful. That's why we take the time to explain these things (plus it's good mental exercise)No, I'm not beginning to get any idea.
So what happens if I let the air out of the tire?We are talking about pneumatic tires with air in it and how air is supporting the weight in its entirety, 100%.
It is not just Wikipedia but a simple search would result in multiple references to that fact.That would probably be best. A couple or posters here clearly understand the physics better than you do. Wikipedia is a great resource for people qualified to interpret it. Yes, ground pressure is APPROXIMATELY the same as tire pressure but as has been shown to you here the approximation can be pretty rough.
@cypho in post #13 already covered it:I was pretty sure you wouldn't be able to but we are always hopeful. That's why we take the time to explain these things (plus it's good mental exercise)
I have shown you, and confirmed by measurements, rough as they are, that there can be considerable error.
There is no confusion with respect to PSIA/PSIG. It is very clear that PSIA must be used because there is no air pressure acting on the bottom of the patch. It is not in contact with the air. The bottom of the patch is intimately adhered to the part of the tire subjected to the internal air pressure. The bottom of the patch therefore is subjected to the same air pressure. The air pressure difference across the patch is, when tyre pressure is 42 psig, 57.7 pounds per square inch. I have explained this more than once and you are either not reading what I wrote or don't understand the basic physics well enough to comprehend. Please don't insult my intelligence. The pressure inside the tire is 42PSI GREATER than the outside air. The pressure at the rubber patch in contact with the ground is 42PSI because it is one with the internal wall. The ground is exerting 42PSI back up at the tire to maintain static state. That is the ground pressure.
What I'd really like to understand is how you came up with this idea that in a pneumatic tire the air column carries all the load "entirety, 100%". Post #46. So I ask questions like what happens if I let the air out and you ignore the question. I ignored the question by quoting Post #13 by Cypho? He already answered it. Do you have any technical background at all? I never asked for your qualifications and really it is none of my business. Just curious and it's really none of my business.
