That’s kind my point. Why aren’t we regularly charging to 100% then? Especially now since batterygate, where Tesla has decreased the amount of power the battery can charge? I normally charge to 90% once a week, and I don’t necessarily need the extra 10% but I’m just curious that if we aren’t really ever maxing out the battery how can giving it a full charge on a regular basis (knowing it’s not a full charge) degrade the battery quicker?100% has never been 100%. If you charge Li-ion cells to 100% you quickly ruin them. It's the same way if you let them discharge down to 0%. That's a ruined battery.
When your car says 100%, it means the maximum charge that the battery management system is programmed to allow, and when it reads out 0%, it means the minimum charge that the system is programmed to allow. Those values are a calculated compromise between available capacity and maximizing the battery's service life.
Over time Tesla have gotten more data on battery life and have adjusted their calculations accordingly.
like I said, I don’t need the extra 10% regularly, and I charge once a week. I was just curious. So “essentially” I’m not saying I want to charge “daily” to 95%.Ignoring the fact there was always buffer on both ends.
Battery gate cost me 10-15 miles that is 4-6% not 10. So essentially you are saying you want to now begin daily charging to the old 95%..............when 90% was always considered the max safe daily.
Tesla is in the wrong here but two wrongs don't make a right and their behavior doesn't make it a good idea for you to abuse the battery.
Just because it isn’t really 100% doesn’t mean that charging higher won’t cause more degradation.
It’s a matter of degrees - Going from 80% cycles to 90% cycles increases wear, too, just not as much as going to 100%.
Understood. Does anyone know how many Kwh we can actually put into an 85 battery, since it’s obviously not 85kwh?
A lot of people misunderstand battery capacity. A liquid fuel tank has a very objective "full", say 10 gallons. This varies a little bit by temperature (tank and fuel), so the energy content of the tank varies a little. In practice the variation is too small to be noticed often. Very cold gasoline occupies less volume for the same amount of energy, so a full tank of sub-freezing gasoline contains more energy than tank at 100˚F. A very full tank of sub-freezing gas will overflow when it warms up.
Batteries are different. A nominal 100 kwh battery if discharged rapidly (lots of rapid acceleration, high speed gaining elevation, with maximum heat or a/c running) will likely only be capable of discharging 80 to 90 kwh, and if the battery is very cold, even less.
Conversely, a very slow discharge may have the battery discharge something like 120 kwh. Further complication is the change of temperature during use, and variation of temperature from cell to cell.
The answer to "How much does a 85 kwh battery hold" is it depends, and is complicated. Tesla changing the charging regimen is recognizing they are still learning about the optimal charging and storage parameters. As others have pointed out, the buffers built into the battery management system for safety and another complication.
BTW, the amount of energy needed to fully charge a battery will be significantly over the nominal capacity, due to inverter inefficiencies, waste heat generation, cooling if necessary, and charging speed. A fast charge will create more wasted heat, while a slow charge (like 32 A) will be much more efficient.
10% degradation sounds really high for 34000 miles. Have you checked volts at 100%? Is it stopping before 4.2v cell values? That sounds like batterygate losses not degradation for such low use.
I have pretty same results. TMS 100D May 2017, 104.000 km driven.
View attachment 486368 View attachment 486370
Tesla batteries are degrading in the similar fashion like all the other manufacturers. The non existing degradation is a myth based on comparing rated miles at % charge. This number changes all the time with various updates and is useles when considering battery degradation.
Hey, what app is this, and what is needed to use it?
If Nissan sold your car with less than full volts at 100% so you can regen that's legal and OK - your car was EPA rated with a cap in place and sold with a cap in place, you have exactly what you bought on day 1.I have often wondered about this. My Zoe charges to 100% indicated, but still gives 5-10 kW regen going down a long hill near my house. Regen does drop off eventually, but it must be pushing the battery over 100%.
Since the notion of 100% seems in reality just a measure of the limits the manufacturer is prepared to push the technology to, what are you actually entitled to? It seems you are just buying a certain design of battery with a certain number of cells.
So if Tesla subsequently decide you will get better service from your battery by changing the operating parameters, you would presumably be OK with that.
