Hello Mr. Vandegriff.
First, as others have stated-thank you so much for all of your postings! I have ambitions to help out the forums in the same way, but I am new to them.
I purchased a Model X 100D at the end of June. On the first trip, I "tested out" pulling a small utility trailer a couple of hundred miles. This only weighed about 2500 lbs max, and did not have brakes. I was pleased with the ease of towing, but also taken aback by the reduction in range. I also went through the Tehachapi area from Buttonwillow to Mojave, but didn't stop in Mojave because I wanted to test my max range (home was further South). I made it about 125 miles with maybe 10 miles at the end.
A month or so later, I rented an Airstream Sport 16'. This was the second Airstream rental (I first rented a 22' Sport, 2017, but towed it with my Porsche Cayenne S). A couple of data points and information I learned:
-the 16'Sport is a wider trailer than the 22' (8' vice 7') and I think that ends up equating to more frontal area and drag, so...if they had been the same weight as loaded, I think the 16' would get worse range.
-I also encountered the LED lights issue-the rental place had no experience with Tesla so I was on my own. What I found, though, was that during the night the car recognized the trailer with LED lights. In the day it didn't. I found that when I simply turned on the parking lights manually (which, again being all LED doesn't use much energy)-the Model X does recognize the lights and thus trailer mode is fine and no red colored symbol. I found that this was an easy compromise and really just makes me more visible in the day-while not requiring any adapter or the possible problems with the adapters coming apart.
-I did not find the range estimation in the vehicle to be very accurate. Towed from San Diego up to Paso Robles and back, so there were only a couple inclines, but they did exist. As you state, planning is vitally important. And I use the Tesla site, etc to see where all currently open Superchargers are, and a lot of iterations with Maps or Google maps, planning distances and stops. A great planning tool, which I got before I even took delivery of the car, is the Digital Auto Guides "EV Trip Optimizer for Tesla". Really the company should provide something like this. It works great on iPad. It can show all the superchargers and plan out a route quickly. It calculates state of charge on arrivals, and you can input your vehicle, the speed you plan on traveling, as well as payload and "Cabin" values, different origin states of charge, and desired reserves at destination as well as power factor.
Now, I did not get good numbers just opening this and planning my first trip, but I iterated some values while towing. I changed the payload and cabin numbers until I basically made the program spit out a range calculation that was "correct"-i.e. it was what a segment I drove ACTUALLY yielded with that trailer in tow. Oddly, the Power Factor is supposed to be where you input anticipating using more power (for example when towing a trailer) BUT, it just didn't really work well. "Cabin" is supposed to be the climate control temperature setting you anticipate using during the trip. You can put in "0" if you anticipate not using the A/C for instance.
For whatever reason, I can not get the program to give reasonable numbers using even the highest "Power Factor" of 6.0, but by adjusting the Cabin value, you can essentially make the program give a realistic estimation of range values for planning. This will be different for different trailers of course, but when I use a Cabin value of 300, this program does a greta job of calculating states of charge and needs for supercharger stops on any given route. I do not know of another way to do this planning, other than manually or sitting in the vehicle with trip planner (which still does not model the consumption rate correctly, and you can't tell it ahead of time what factor to use).
It isn't an aerodynamic model, and it isn't a terrain-smart model, but by tricking it a little, you can make the program do a good job of trip planning for charging. This might be interesting (and is a free app, with a couple of $2 pro options) for readers who want to play with possible trips and this vehicle in a towing role. I will update a good "Cabin Value" from empirical data once I have towed a heavier trailer a few segments.
NEXT: I just purchased an Airstream 20' Flying Cloud. It is heavier than the 22' Sport, but has a GVW of 5000 (which my X "should" be fine with-at least as advertised). I will be towing it from Portland to Los Angeles next month, so....my real first test is this:
Can the Model X tow a 5kGVW trailer on this route using the Supercharger network only?
The longest leg is Eugene to Grants Pass at 138 miles. (until they open the Roseburg Supercharger). I am doubtful that I can make this leg at 55MPH. My backup plan is to stop in Roseburg and use a level 2 charger of some brand to plus up.
I will post results of this experiment, but essentially, I want to show whether the advertised car, with largest battery, can actually tow the advertised weight on the Supercharger network.
-Yes, it will be inconvenient, and I plan to unhitch for most of the stops, as I did with the 16' I rented.
-I will post places that are possible "leave it hitched" stops (I know Buttonwillow CA is one, as you can pull adjacent to the superchargers on the side where there is a drive through, still leaving room for traffic to get by, and not taking any supercharger spaces.)
If anyone is seeking specific data in a configuration like this, I will try to capture it on this trip.
