miimura
First, 10-20kW AC Level 2 will not be provided by any automaker other than Tesla - and even Tesla seems to be deprecating the second charger now. Second, since every EV in America that doesn't have a Tesla on-board charger has one that is less than 8kW, there has to be some kind of DC charging >25kW. Obviously, the higher the DC power delivery the better. I would argue that the network that NRG is building now in urban and suburban areas is a bridge that allows people to consider the available "city cars" as a viable alternative. I also think that if they can do away with the No Charge to Charge programs that encourage excessive use, then the network would support an order of magnitude more cars than it does today. There was a study in Japan that concluded that the mere presence of fast chargers in the area made people comfortable enough to use a much larger percentage of their battery on a routine basis - even when they never used the fast chargers. It will take a REALLY long time for there to be useful AC-L2 at every place you actually go as a "destination". For the existing affordable cars on the market, the current build-out of DC chargers is important.You really still don't get this. It is impossible to use 25-80 kW L2 DC EVSE's to realistically support a significant BEV infrastructure. The costs are way too high. The benefits are way too low. We need far cheaper charging points spread all over - the destination charging network and in North America, that means J1772 AC Level 2, ideally at 10-19 kW. For high speed charging, that's Level 3 DC, or 200-400 amps for 100 - 150 kW. The high cost of L3 is only worth it to support long distance travel and therefore most people don't use it for everyday commuting. Anything else and you are talking about 5x to 10x the cost with reduced number of plugs which means congestion and the inability to rely on the charging network.
The first generation of BEV's... the i-Mievs, the Leafs, the Ford Focus Electric and so forth cannot be used as a template for the infrastructure to support 1,000,000's of BEVs on the road. It is foolhardy to try to build the infrastructure to make these vehicles into all around vehicles. The costs then rival hydrogen infrastructure costs.
Just to show that I understand your point, I don't think that ANY charging infrastructure could make a Leaf, a Soul EV, or an e-Golf into a viable vehicle for a 400 mile road trip. For that kind of trip you clearly need a much larger battery (50kWh+ usable) and truly high power chargers located on all significant travel corridors. It will take a long time for the other automakers and charging networks to catch up to even where Tesla is today. However, that is not a good reason for them to sit on their hands either. The current standards are all they have to work with and for a significant number of people on the west coast, it is workable.
