CapitalistOppressor
With just over 30,000 miles the range charge gives 254 miles down from 275.
Everyone should take note that the folks who are seeing significant degradation are very high mileage drivers. I've seen 16k miles, 21k, 30k etc. and we know that almost every car delivered has been in the last 12 months, with most in the last 8.
The answer to this thread is complicated. But it's important to realize that the batteries that Tesla uses are probably good for 3,000 cycles when the battery is experiencing the kind of shallow discharges that most drivers of an 85kWh battery will experience. 3,000 cycles times 265 miles is ~795,000 miles. As far as I know, that testing assumes 60% capacity remaining.
But when you are deep cycling the battery (ie using a large portion of your rated range each day) the number of rated cycles moves closer to 500-1000 because of the additional stress you put on the battery. That's almost certainly why we are seeing high mileage drivers already losing 5%+ of their capacity in the first year.
That is also why the 85kWh battery gets an unlimited mileage warranty, vs 125k for the 60kWh cars. The smaller battery requires deeper cycling for the same amount of driving.
