Don't know if some "normal" HK home appliances use 3-phase. At least the power supply is available in 3-phase from CLP, e.g. my place and even at a friend's village house in Sai Kung.
Tesla should give us based on what supply is available and not what other appliances can use.
It's not a question of whether you have three phases or not.
It's whether it is legal or not, combing two phases into one consumer unit, instead of only one phase and 0/neutral.
Most of your appliances plug into a normal 13A 220V AC outlet, the one already discussed so much on these forums. One pin is a phase, the other is 0/Neutral, and then finally, the third (lower/middle) pin is grounding (and most often not used). Each of your items then, use only one phase. If you could use two phases, you could heat your oven/laundry/iron forge much quicker.
Or charge your car faster! Use three phases, if possible, and it would be even better! The HPWC only has two connections, so two-phase seems to be the limit. With a 1 cm cable from charger to car, I doubt the currently offered HPWC units will even be conveyable to two-phase, correct me if I am wrong.
Phase + 0/Neutral = 220V AC
Phase + Phase = 380V AC (not sure if this is what is called "split phase", I'm just used to calling it either 380V or 400V, then people know it's using two phases)
These are two types of 380V AC (or 400V AC, for a 230V AC system), that I know of from Europe:
As you can see both connectors have 5 plugs: Phase 1, 2 and 3, 0/Neutral and ground. That doesn't mean they are always used, but normally, sockets have all three phases, then it's up to the connector which phases are used.
It has been like that even since the 70's, maybe even before, when I grew up. It's not new technology at all, but I am not sure how widespread this is in Hong Kong - and whether or not it is even allowed for HK consumers to combine two phases to make use of 380V AC.
As far as this wiki page suggests, Hong Kong supports three-phase:
Three-phase electric power - Wikipedia, the free encyclopedia
More reading here also
Three-phase - Wikipedia, the free encyclopedia
I
totally understand Tesla Motors are cautious. If there is just one single fire or other serious problem, and they are not 100% covered legally and technically, all hell will break loose - spearheaded by Apple Daily I'm certain.
