This uses the Alien Gear Holsters ShapeShift system to put a detachable holster in to the center console area of a Tesla Model S. I did this in a December 2017 Model S. There may be some slight modifications you will need to perform on your vehicle. This should only be performed under the full understanding that I am not giving directions on how to install this kit in your vehicle and that I am only showcasing how I did it. Always ensure that any and all firearms are unloaded if you decide to try something like this. I assume no liability for any damages or harm you may do to yourself, vehicles, or others.
The Alien Gear Holsters ShapeShift system can be purchased from
ShapeShift Modular Holster System by Alien Gear Holsters It includes several carry methods as well as the holster mount that I used to mount in my Model S.
Below you will find the steps I took to install this holster system in to my Model S.
You will need a 7/32 drill bit. If you are going to do this by hand like I did, be sure the bit is nice and sharp. I used a Hercules Titanium bit set from Harbor Freight Tools. Works great.
You will also want some M4 washers. I had a set from a TV wall mount that work perfectly.
This image shows the holster mount with a weld nut in one of the corners.
Flip over the holster mount with weld nut in it and verify the M4 washer you have fits around the weld nut perfectly.
To help make sure you get the proper clearance before drilling, put an M4 washer on the 7/32 drill bit as it will help you align in the corner of the first drilling spot.
To make sure you are aligned properly, you will want to put the drill bit and washer in the upper left corner of the area shown in the picture. Be sure the washer sits flush against the outside wall of the compartment bin in the location shown and then you can start drilling. I spun the bit a few times to mark the spot with the washer in place, then removed the washer to finish the drilling. I recommend a rag to catch the plastic shavings.
All the way though for the first hole. This hole is important as it will be the alignment hole for the rest of the mount.
To make sure the hole is clean, I went back through it spinning the bit in place from inside the compartment bin side to be sure the hole was nice and smooth. I recommend moving the cloth/rag to inside the compartment bin to catch plastic pieces before starting.
You should have a nice clean hole.
(Continue in next post)
