So, I got to drive one today. Competent. It's got the normal advantages of an EV - low latency response on the throttle, no vibration. Steering was pretty good. I guess American cars have finally gotten halfway decent on steering. The center console is interesting, but not to my taste. Yeah, capacitive touch switches (easy to keep clean), but didn't register quick taps. Not Apple quality touch. The data displays are over-simplified and over-illustrated - I didn't spend much time, but there wasn't anything that popped out as immediately obvious as the Roadsters current flow display, much less the nanny-graph. There's one vertical bar with a green bubble inside of it that moves up and down, and gets smaller & turns yellow if you're not driving 'efficiently'. I found it more annoying than helpful. I called it a hybrid, the representative had probably been coached given the re-emphasis on the phrase extended-range electric vehicle (wake up GM, stop it!).
But, for me, the BIG annoyance was the combination of the blended-on-the-brake regen (which sucks, sucks, sucks), and those aforementioned lack-of-real-info displays. I can only guess that when the stupid floaty green ping pong ball got to the first tick down that I had hit the limit of regen (and if so, pretty wimpy!). They did too good a job on blending, I could not tell when the friction brakes were kicking in. Absolutely the wrong answer!
My verdict: they've nailed it for the soccer mom worried about the environment and who has a bit of range anxiety and isn't willing to give that up to reason.
(I also got to drive a Corvette for the first time. Gawd, do people actually buy these things? I don't care how fast it goes 0-60 when the steering isn't even as good as the Volts', and the power output is so non-linear and unpredictable! When I stomped on it and the other 4 cylinders kicked in it was just a loud, obnoxious, unruly mess. It was fun for 5 minutes in an I-hate-the-earth-and-everyone-around-me kind of way, but after sitting at a stop light and missing the peacefulness with the shaking and the rumbling and the wasting... They had some other cars to drive, but that pretty much sopped up any ICE tolerance I may have had.)
