LOL. Then we disagree. In my opinion, you're the one "gatekeeping EVs".
You're expecting ICE drivers to switch from 5 minute gas tank fills to "carefully plan your charging on a 120v". This will push people away from EVs. Giving someone a bunch of details and technical info just scares them.
what is this? I did not say that they have to carefully manage on 120V. I said that if they could manage on 120V, then they can go with 120V. If they determine that they need L2, then get L2. Obviously someone who drive like 200+ miles / day is not going to get by on just 120V charging.
You're the one who's gatekeeping, saying that only L1 = no EV for you (unless you fit a very specific profile). I'm saying If you can get by with L1, ev for you!
Believe it or not we are still "early adopters"... but the average consumer will be leery and range anxious about switching to EVs. Most ICE drivers I talk to still think that electric vehicles are only good for local driving.
What the average consumer needs to hear is something like "it's just a dryer plug in your garage".
As building codes change and evs becomes more popular, this will change. I agree that we would like to get to that point eventually .
What they DON'T need to hear is something like "you might be able to use a regular plug, how many miles do you drive a day? Just make sure you plug it in every time you get home and don't forget even once... also, in winter you might have problems, what's your average winter temperature? Maybe you need to park inside the garage... remember that short drives will waste a lot more energy preheating your battery... consider keeping your ICE vehicles around just in case".
Anyone who is already comfortable doing their research doesn't need us to tell them that they might be able to get by with 15A, however that information is already stated in this thread and I reiterated it... 15A will work for some people, some, most, or all of the time. For others though, 15A is insufficient.
I stand by my original sentiment - EV owners should get L2 charging if at all possible.
You're making it a lot more complicated than it needs to be. Those questions don't have to be asked like someone is being interrogated by TSA in rapid succession, a lot could be boiled down to
- how much do you drive on average
- where you live
- where you park
I do agree that if one has to ask a ton of questions to determine viability of L1 charging, then yea at that point it probably is better to just go to L2. But if the questioning can be kept limited and scoped, then I do not see any issue with that.
I don't think our statements are incompatible. To be clear, I feel if one can, then yea upgrade to L2. But if that's not possible for whatever reason, if your driving pattern works with L1, then you can stick with that for now.
You make L1 charging sound like its some tightrope thing to walk where if you don't do exactly x,y,z then your car will fall apart. At the more extreme ends I would agree. But if your driving profile fits L1 charging if you treat it as if it were a L2 charger, then you can be fine with that for now at least. I would argue that there's a lot more people that could comfortably work with L1 than you think.
