New video of Go on Green:
Seems like it considers lead vehicles pretty far ahead.
Thanks for sharing. Looks like it works really well.
Yeah, this is why when I use it, I'm on TACC, which still lets you set the speed over the limit. My usual commute has the speed limit mistakenly set at 5 mph below the actual limit, so it's even worse for me if I use the full AP.Looks good- though it's funny the "absolute" speed limit means you keep falling far enough behind your lead car that it stops working
So, looks like, with this we are back to the old AP in terms of not needing intervention when we have a leading car.I got 2020.24.6.1 today and got a chance to test real quick. It did require confirmation on green even with a lead car on some lights but it worked on other lights. The release notes do say that the car needs to be confident that the lane is not a turning lane so I wonder if for some intersections, AP is not 100% confident so it still asks for confirmation. But when the no confirmation did work, it was very nice. One less thing that the driver needs to do. It is a small incremental improvement. Hopefully, we will see even more improvements soon.
Right.Not quite. This feature will stop automatically at a red light with no lead car and no confirmation which the old AP could not do. It is only for green lights that it behaves similar to the old AP.
Right.
But usually if you have a lead car, it would stop for red light.
Anyway, a good improvement- probably an easy one.
BTW, I was listening to George Holts interview on 3rd row podcast. He is trying to do end-end, even for traffic lights. Would be interesting to watch how it goes.
That's actually impressive.Here’s a photo
It was pretty inconsistent in my brief test as well. My theory was that it doesn't drive through green when you're on a lane from which you could make a turn at the intersection (even if it's not a turn-only lane), but I haven't tested it enough to be certain. The inconsistency is annoying since you always need to keep an eye on the screen to see what's happening if you want to avoid sudden slow-downs. Turned it right back off. Not really usable in its current state.Anyone noticing that the new "go on green" with a lead car does not happen very often? In my experience, it only triggers on certain intersections (per the release notes) but also only when the light was already green and the lead car is close and clearly crosses the stop line on green.
Anyone noticing that the new "go on green" with a lead car does not happen very often? In my experience, it only triggers on certain intersections (per the release notes) but also only when the light was already green and the lead car is close and clearly crosses the stop line on green. So it won't trigger if the lead car crossed the stop line way ahead of you. And it won't trigger if you are stopped at a red light and then the light turns green with a lead car in front. At least not in my experience. Maybe it does, just not on the intersections that I've tested it on. But I am finding that I am still having to confirm with the stalk on a green light, with a lead car, most of the time.
