probably my firewall...let me take a look
Due to the distance the transformer is from the electrical room ~300ft, 480v became 470v, which made the 208v secondary 200v. We had to change the input tap to compensate for that...Now we are on tap 6, which is providing 214v down at each station...which begs the question...if these cars can handle 240v, why wouldn't we just crank the 208v up to 230-240v? Anyone try this before? I don't see a drawback unless the primary side moves up significantly?
The nominal Voltage for J1772 L2 charging is 208-240 Volts, but we know that there is tolerance. I believe that the Tesla AC charger can take 100-250 Volts AC and versions can go up to 277 Volts nominal in Superchargers.
Let's do a little math on tolerances. If the input is 470 Volts and you use Tap 7, the output will be 470/432*208 or 226 Volts. Let's look at it another way, if the input rose to the highest this transformer expects or 504 Volts, then the output rises to 504/432*208 or 243 Volts, well within ranges normally seen by J1772 vehicles. I often see 250 Volts or very close at my Pagosa house when the Solar system is cranking out 20 kW to match the Tesla 20 kW load.
As long as there are no loads that actually expect 208 Volts, I say go for it. 9% faster charging is good for everyone! The only complication is that you will have to take the new output Voltage into account in your calculations for keeping the total kVA within limits on each transformer, but that should be easy.
@FlasherZ: I'm surprised there is nothing in the code that requires +-10% of 208v. Good point on the L-N...looks like we will have to invest into some permanent signage on the panel...
We were told it has to be in rigid conduit, and yes it was a pain in the ass to install all of that conduit.
