bollar
Disgruntled Member
So, they're installed and they work fine. Still not sure how I feel about the size of the gizmo attached to the valve, but I'll leave them on for now.
I'm too lazy to go research it so instead I'll just ask here (I notice a couple of very technically inclined people now have these sensors): What is the certified precision of these sensors? I see from the the screenshot above they display 0.1 PSI increments but surely the rated sensitivity is not +/- 0.1 PSI? Does the manufacturer publish test data supporting a certain precision rating, as compared to a gold standard method for tire pressure measurements?
Anybody tried the Papago sensors? Rated up to 60lbs...
GoSafe TPMS 500BT |
http://www.bhphotovideo.com/c/product/1064028-REG/papago_gsbt500_us_gosafe_500_bluetooth_tire.html
Just pre-ordered. I don't want to wait for Tesla to make this change. I've been burned twice already with low pressure readings that then require me to put a pressure gauge on each tire to find the culprit -- one incident was late a night at the airport.
Looks very similar to the FoboTire system. I wonder if we'll see an IP battle between the two companies? It certainly seems that somebody's ideas were purloined.
I'm having the same issue lately with losing connection to the front left tire. In car unit beeps a long time and then eventually it corrects itself and begins displaying properly.
I'm having the same problem with the right rear sensor. It's been indicating low pressure for more than 24 hours even thought the tire pressure is spot on (checked it with a gauge). This is not a faulty sensor (swapped out a spare and got the same results). So I suspect it's a faulty tire air valve. Will reset tonight to see what happens.
Update: When I drove home tonight the low pressure warning showed on the dash screen, so the Fobo proved to be accurate. And it gave me a low pressure warning 24 hours before the Tesla system and it accurately identified the specific tire. Impressive!
i was debating whether to get this system. Your post convinced me. That, and the fact that the unit uses batteries rather than USB, so it will report when the car is off, makes the Fobo a better choice for me than the Papago system.
As it turns out, that tire had a defective valve that has to be replaced. This morning when I attempted to add more air and check the pressure, the Fobo readings again proved accurate I could only get the pressure up to 40 psi (used my gauge to check it) and when I reinstalled the Fobo sensor it had the same reading: 40 psi.
I've read that the FoBo system has a maximum pressure that can be set of 44 psi, even though it will read and report higher. The 21" wheels have a recommended pressure at the limit. Does this pose issues I should be aware of?
