All AC charging (home charging) is so ”slow” that there isnt any win in reducing the charging power for the battery longevity.@AAKEE , on top of all good suggestions you have here, will charging at lower amp (16a) or max (48a) make a difference in term of battery degradation? Many thanks.
I'd say there's a win for battery longevity when charging at a higher amperage. Used in conjunction with Scheduled Departure, this would allow the battery to sit at a lower SoC for longer, and thus reduces the average SoC and calendar degradation.All AC charging (home charging) is so ”slow” that there isnt any win in reducing the charging power for the battery longevity.
At max AC charging, 11kW it is only 0.15C or so.
Absolutely!I'd say there's a win for battery longevity when charging at a higher amperage. Used in conjunction with Scheduled Departure, this would allow the battery to sit at a lower SoC for longer, and thus reduces the average SoC and calendar degradation.
The smaller the depth of discharge is, the better.AAKEE,
Things get confusing fast here. Could you give a summary of your oppinion on the following (not looking for practical just pure battery):
For daily use what should the ideal state of charge range be? 20/30. 10/30 20/90(T recc).
For the battery life due to charging power, we can not set a home charging rate that is high enough to start reducing battery life due to the charging power.What charger/rate should we use(tesla home charger 24048A or 110v)? Slow or fast?
It is not always needed.Always prep the car(takes up to 40 mins)?
Probably not from the principles above but if yoy describe the climate or difference I’ll give it a try.Any adjustments for say Ontario weather vs Alabama?
Ok, I get it now...albeit quite a few reads later. Thanks.The smaller the depth of discharge is, the better.
The lower the SOC is, the better.
This will be more of a theoretical discussion. There is a not a big difference between 30% to 20% and 30% to 10%. Both will give very low degradation.
-30-10% will give lower calendar aging, if the charging is done late so the car will spend the night at low SOC.
-30-20% has a smaller depth of discharge, so it will possibly give slightly lower cyclic aging
There should not need to be a choice of 30-10% vs 30-20%. If 30-20% was possible to use (10% depth of discharge) there would be an option of using 20-10% also.
This would take the advantage from what I wrote about both choices about.
You can se that there is not big differences between 30 and 20 and 10% at normal temperatures. Blue line at these points.
Below we can se that cycling at very low SOC gives the longest life.
In the chart we should compare cycles with the same load ( C ). In the car charging home and driving is about 0.05 to 0.25C so the cycles marked 4C can be disregarded.
Except the high load 4C cycles, its always better with lower SOC range during cycles.
(10-20% was better than 0-10% at 4C).
This chart does not show NCA Chemistry, but it is good at clearly showing different SOC ranges.
Noye that 0-10% and 10-20% have an average cyclcle number before loosing 10% SOC (end of yellow band) at 6000 FCE cycles compared to 60-70% that averages about 1500 FCE cycles.
The principle is that the lower the cycle range is placed, the less degradation.
20-90% will give much more degradation, so it should only be used when the range is needed if low degradation is the goal.
The highest possible we have in europe is 11kW charging power (three pases of 230V and 16A) That is the limit of the on board AC charger.
Reducing charging power will not save or increase the battery life.
This means that *Any home charging power* will cause very low /about the same cycling losses. You can select whatever charging power you want at home, or i limited by the net limitations.
What @STS-134 wrote/meant is that if we use the “charging late technique”, charging as late as possible, we can set the charging to start later which in turn gives shorter time at high SOC as the car continue to be at lower SOC until the charging starts.
This is only valid when using the charge late technique. Thats the reason I didnt mention this in my first answer.
If the charging is started at arrival at home so the car will be parked a long time with the charge finished a high charging power gives the opposite result, the car will be at a higher average SOC increasing the calendar aging.
In summer, not needed.
If it in a varmed garage, not needed.
If you charge late, not needed.
If the car is outside at sub freezing, was not recently charged and was not driven the latest hours it can be good.
But the car itself heat the battery when the driving is started so the battery will only spend very little time at low temps.
I do not always precondition if it is outside and has cold soaked. Each winter I do several Drives which was not pre planned somI start the preheating with the app when I decide to go or start taking clothes on.
Still, my car has very low degradation.
Going below 40% reduces degradation. It does not increase it.
No, thermal runaway does happen at low SOC.I have a personal experience with my cell phone becoming noticeably hot at a lower SoC. At or below 5% SoC, which probably equates to a cell voltage of 2.7V or less, a thermal runaway can happen.
I'm not sure if the Tesla BMS has a built in protection or buffer to protect the battery pack. I hope to get some expert advice to understand the Tesla's BMS capabilities?
We all have to decide how to charge from our own preferences. As long as anyone do not charge to 80% because she/he thinks that it will give the lowest degradation I’m happy.I mean from a practical standpoint low SOC cuts degradation by half right.
In my case 250 miles base model 3 range 5% vs 10% is literally a 12.5 mile difference in which the grand scheme of things doesn’t even matter lol
For myself, I often need a big part of the range. My job is 240 km away, and in wintertime it can be -30C or colder, making the cars range about 300km, when I drive home (parked outside, slow charhe so relatively cold battery). In these conditions its not safe to aim for arriving with 0%.I mean from a practical standpoint low SOC cuts degradation by half right.
Thanks for bringing up the end of life capacity number for discussion. I totally agree with the known best practices in the battery industry that a level of battery degradation above 20% is considered the end of life. At that number, even when an EV owner has 90,000 mi (145,000 km) on the vehicle, it will be unsettling. At that point, assuming you're not plain old angry, you're genuinely disappointed with Tesla. Interestingly, however, Tesla would like you to keep driving until that degradation number hits the 30% mark. This is not a sustainable position. As the competition from other EV manufacturers heats up and the battery tech gets better really fast, Tesla would hopefully be thinking about this issue. Tesla should consider revisions to their battery warranty statement, adding a prudent limit (research guided) of Supercharging sessions as one of the important qualifying criteria, amongst other conditions. What are your thoughts about it?The industry standard for lithium ion batteries is that they are consumed when reaching 20% degradation (80% capacity).
Tesla is not in the business of replacing batteries for free. Thus they have set the warranty criteria so that the vast majority of cars will not reach the 30% degradation threshold by the time warranty runs out. If they lowered that threshold to 20% they would likely have to replace significantly more batteries.Thanks for bringing up the end of life capacity number for discussion. I totally agree with the known best practices in the battery industry that a level of battery degradation above 20% is considered the end of life. At that number, even when an EV owner has 90,000 mi (145,000 km) on the vehicle, it will be unsettling. At that point, assuming you're not plain old angry, you're genuinely disappointed with Tesla. Interestingly, however, Tesla would like you to keep driving until that degradation number hits the 30% mark. This is not a sustainable position. As the competition from other EV manufacturers heats up and the battery tech gets better really fast, Tesla would hopefully be thinking about this issue. Tesla should consider revisions to their battery warranty statement, adding a prudent limit (research guided) of Supercharging sessions as one of the important qualifying criteria, amongst other conditions. What are your thoughts about it?
Unless I am reading the wrong, Tesla battery warranty goes to 30% degradation. I saw this in the Tesla battery warranty found here: Vehicle Warranty | Tesla SupportI totally agree with the known best practices in the battery industry that a level of battery degradation above 20% is considered the end of life.
Its not improbable that the battery pack start to give fault codes and work bad before reaching 30% degradation.
