For a Model 3+ (being delivered next week), how many miles driven per hour of charge will I get from a wall charger wired into a 60A breaker? I've seen people say 44 and I've seen people say 32. What have you actually seen from your wall charger?
SR+? Current wall connectors deliver 32 amps at 240 volts. Multiply those two numbers together and you get a rate of 7,680 watts. The SR+ has an EPA rated from-the-wall efficiency of 250 watts per mile. Divide 7,680 by 250 gives you just over 30 miles of range per hour of charging.
In the end for the SR+ your final number is a bit high but basically correct (your math gives 31rmi/hr). However...
SR+ has a 55kWh battery and a range of 240 rmi, so maybe it is closer to 230Wh/rmi.
Also, the Tesla table appears to be aimed at the RWD versions of the Model 3 only, and appears to assume ~230Wh/rmi (the actual constant for the LR vehicle and the SR+, approximately).
In addition, your math does not account for charging losses.
7680W* 0.9 = 6.91kW (delivered to battery)
6.91kW / 230Wh/rmi = 30rmi/hr
For the AWD, since it gets 310 rmi out of the 75kWh pack (rather than ~325 for the RWD), it is closer to:
6.91kW / 242Wh/mi = 28.5rmi/hr
Summary: Tesla table is slightly optimistic for the AWD versions of the 3. Just something to be aware of. People sometimes get confused about the extra 10% of energy they have to put in their packs as compared to their rated mile use, when they have a meter on their outlet.
The EPA rated 250 wh/mi factors in charging losses. It's an average measure of how much you can drive from the electricity measured from the wall. It does seem like an odd thing when you think about it. The EPA wouldn't rate an ICE vehicle's MPG higher if they frequented leaky gas pumps!
The expectation is that gas pumps won't leak. If they all leaked 10%, we'd have a major problem on our hands.
Is DC charging have more or less efficient than AC charging? Maybe about the same, possibility less. 50kW DC Fast Charging units are about 92% efficient converting from 3ph 480VAC to 400VDC. That’s about the same as 240V AC charging. Here’s some data on a popular DCFC from INL: https://avt.inl.gov/sites/default/files/pdf/evse/ABBDCFCFactSheetJune2016.pdfMaybe this is a question for @Zoomit , but do Tesla vehicles experience more or less charging loss when DC fast charging? I assume most of the loss is in the AC/DC conversion; so the EPA may be understating the efficiency of the cars if you only supercharge.
The SR+ tested to 247 mi per the EPA documents and was voluntarily lowered to 240 by Tesla.It also suggests that if it really does have a 55kWh battery, the rated range of the SR+ of 240rmi seems a bit pessimistic.
If your question is whether there are fewer losses from Supercharging, I’d guess not. Just like accelerating quickly takes more energy to get up to speed, pumping electrons into the battery faster will take more energy.
I think the question that was being asked here is from the DC out of the supercharger, to when it makes it into the battery - what is the efficiency? Presumably the only losses will be the heat generated as charge is pushed into the cells. (There won't be any AC/DC conversion loss in the car.)
As you say, presumably the efficiency of a Supercharger from AC to energy delivered to the battery won't be much different than a home setup (presumably it might typically be a bit worse depending on I^2*R heating losses); it's just dependent on converter efficiencies and these other heating losses.
I have always assumed that Tesla bills for energy delivered to the battery, which provides an inherent benefit to Supercharging as far as cost goes (well, Supercharging is really expensive to begin with, so really more of a discount on Supercharging when comparing to the cost of charging at home - home charging of course will normally win out and has the benefit of not being a huge pain in the rear). However, I have no idea, as I have free Supercharging, and I also don't ever Supercharge.
The losses from a Supercharger should be similar. It’s just a stack of 12 of the chargers that are in the car, grouped together.
I don't know what power value Tesla measures to tabulate the Supercharger bill, but we do know what the power reference is as shown on the screen during a Supercharging session. Those kW's are power delivered to the battery and don't include car HVAC. This is hard to determine from a Supercharger, but can be discerned from European CCS stations. Bjorn has a recent video that shows DC Fast Charging his Model 3. The DCFC unit shows it's power output and he compares it to the in-car displayed value.Sure, as I said above, that is true, but the question was: do you get better cost efficiency? At home, you pay for what you pull from the wall. What does Tesla charge you for (my guess is energy delivered to the battery)?
(And even if they charge for energy delivered to your car charge port (rather than the battery), would that still be better, and if so, how much better?)
The question really (as I understand it) was: how much of the energy delivered to the car charge port makes it into the battery as useful stored energy in the case of DC charging? In the case of AC charging it is ~90%.
(And a related question is what does Tesla charge for when supercharging? 1) AC power 2) Power delivered to car charge port or 3) Energy stored in battery during session?
My guess is 3) (meaning you would not pay for any conversion and battery heating losses) but I have no idea.). Does Tesla charge for energy used to heat your battery when it is cold arriving at a Supercharger? Also I have no idea...
The answer to this question is challenging because it requires knowing the battery usable capacity. The Tesla EPA submissions have two examples of LR battery capacity measurements: 78.269 and 79.218 kWh. We can average those and assume 78.74 kWh. u/Wugz has some accurate charging session data posted online. I looked at a 9 min period of steady 145 kW charging and calculated a 2.5% charging loss.The question really (as I understand it) was: how much of the energy delivered to the car charge port makes it into the battery as useful stored energy in the case of DC charging?
