mellington
I haven't had the most detailed read though this thread, but I get the feeling that these problems are torque related. Are these issues related to owners of P85 cars or those with a heavy right foot?
I doubt it. After I had my first replaced, I babied the accelerator. Still developed again.
I may have just had this happen to me! I am on my way home from TMC COnnect and I heard a mild CLUNK every time I lightly pressed the accelerator or let up on it. Leaving Monterey it seemed a bit louder. By Barstow it was significantly louder. After Kingman I called Tesla and detoured to Phoenix to go to the service center. I didn't make it! Car quit about 10 miles away and had to be flatbedded into the SC. Will know more later today. YUCK!!!
Call me a skeptic on this whole thing. Tesla's replace vs repair approach means that a drive unit replacement is the standard action for any number of potential issues, so to lump all the different possible failure modes into one category is flawed analysis. Second, I would think Tesla is aggressive about rotating drive units back to the mother ship to see how they are holding up.
Finally, if you look at the numbers Tesla reports in their financial reporting (page 11), back in Q1 of 2013, Tesla reported warranty costs of $3,107,000 for a population of 7,550 Model Ses delivered to date for an average warranty cost-per-car of $411. This last Q1, Tesla reported warranty costs of $9,300,000 for a population of 31,584 Model Ses for an average cost-per-car of $294.
Since I have not seen any upwelling of complaints about service that would indicate Tesla is getting stingy with warranty repair work, what this says to me is that Tesla is getting better at building defect-free cars (yay) and there would not appear to be any pervasive issue with an apparently big ticket item like the drive unit.
Anyone know what happens with the drive units?
The reworked drive units would be more prone to repeat failure, given that there is a greater than zero percent chance of incorrect diagnosis of the root cause of a fault. This would account for there being a significant amount of people who replace their drive unit multiple times
I work with finding and repairing faults on high-tech products. Sometimes you can't be exactly sure what caused the fault. You find yourself unable to reproduce the fault, or you fix whetever is broken, only to have the product fail again down the line. As an example, if a drive shaft snaps - what caused the fault? Imperfections in the shaft? Imperfections in the bearings? Improper alignment of the shaft? Maybe it was something else entirely? Sabotage? Gamma-rays for outer space?Not sure if I agree with you here. Assuming they understand the root cause and have developed the appropriate fix, I am not sure this would be the case. As one data point, I had the "drone" at ~10K miles and got remanufactured drive unit which has been happily propelling me down the highway for 20K noise-free miles so far.
You are also assuming the repeat failure has the same root cause as the first failure. I think that is one of the reasons they record the motor sound and upload to Fremont, because they can differentiate different failure modes, even if they sound the same to the untrained ear.
You often find yourself in situations where, after you have done everything you can, you are 90% sure you've sorted out the fault, but you can't be entirely sure because there isn't enough data, and the only way to get enough data is to do destructive testing, which kind of defeats the purpose. If the fault hasn't been corrected, it will in all likelihood happen again once the product starts being used regularly. The question is what you do then; do you toss the whole thing in the garbage and get a new one, or do you assess the risk as acceptable?
For safety-critical things, one might err on the side of caution, but if all it does is cause another trip to the service center, maybe that's acceptable. Now, I don't know what Tesla's pratices are. They might accept a high degree of risk, or they might be very quick to toss suspect HW in the garbage. But regardless, with a repaired unit, the chance of repeat failure will in all likelihood be to some extent greater than with a fresh unit.
There are certianly factors working for and against repaired units. One element is also that units that have been broken in. Failure rates follow a so-called bathtub-graph. High at first, then low for a long time, and then it starts rising slowly. With repaired units you are certainly past the initial high failure rate, for all parts not replaced in the repair. Provided a drive unit has been correctly diagnosed, a repaired unit should be as good as, or better than a new unit. I think that's about as much as one can say without more data.I disagree. A remanufactured unit is going to get more individual attention. The build rate is certainly slower and requires inspection of all the components. Brand new drive units have to be manufactured in mass to satisfy Model S production. Remans only need to rebuilt fast enough to supply service demand, which is arguably far less. When remans are inspected, problems that may not have been caught on the line may be revealed and addressed. It just depends on how Tesla does things.
(LMB spouse)
Drive unit replaced once, at around 6,500 miles, for moderate but increasing 60 MPH hum/roar noise. Interestingly, the P85 loaner LMB got had the same noise but much louder. The Watertown (MA) SC manager said he didn't fix it because then it would sell and he would have even fewer loaner cars. This was before the 90-day-loaner-retention policy.
Anyway, the noise has not returned and the car is up to 19,000 miles. It has developed a moderately annoying whine at low power levels, 5 to 25 kilowatts. This is *not* the whine/squeal under hard acceleration. Instead, the volume is affected by the power level, which unfortunately is in the range of typical driving at moderate to highway speeds.
Hmm... This is similar to the noise/behavior that my original drive unit was experiencing and Tesla decided to replace it when I took it in for it's annual. I was surprised actually. It seemed have a moderate whine or resonance at speeds 55 to 70 mph and low torque on the motor (5 to 20 kw). Seemed to me like it was just the way the gears "broke in" and was not going to fail or get significantly worse. It didn't bother or worry me enough to have Tesla look at it. It started do that after about 5000 miles and didn't really get much worse until they replaced it at 21,000 miles. The replacement drive unit has a different "feel" than the original unit ever had. It seems like the gears (different ring gear & pinion) are cut slightly differently. They mesh tighter and resonate at lower speeds and high torque where it is not noticeable. The result is it is absolutely silent at almost all speeds and especially the 55 to 70 mph speeds at low torque. Exactly where the original unit was loudest. I could be wrong because tesla never said what was actually wrong with the original drive unit and I didn't press them much on it. I have been happy with the replacement unit thus far at 27,000 miles.
