eprosenx
So I am going to ask a question that I think is going to result in two things:
1. Everyone knowing that I am NOT an electrician
2. Everyone saying "noooooo, do don't that!"
So here goes:
If I have a regular outlet (what I have now learned is a NEMA 5-15), can I simply change this outlet to be a NEMA 6-15 outlet? It's the same amperage (and I can see in my panel that it's a15 amp breaker), but would result in more voltage and higher charging. I would need to buy the adapter, but this would seem to be a much cheaper way to increase my charging speed.
Electrical context: My garage has a garage door opener, but that's not plugged into the outlet I would be using, but rather another one. They are all on the same breaker though, I think.
Let the noob condemnation rain down! .
Yeah, if there is only one circuit to the garage then likely all the plugs (including the garage door opener) are likely on that circuit. Your idea is a good one though and it would absolutely work if there was nothing else on the circuit. Even if there was say two plugs on the circuit, but you did not need them for anything other than charging the car, you could disable one outlet and convert the other to 240v. This would slightly more than double your charge speed.
Now it likely would not be code compliant just because you would not have the required # of plugs in the garage, but it would not be a safety hazard.
Though you probably would not have any lights either?
I still want to know how the wire gets to the garage from the house. If you were lucky you may be able to pull additional conductors into that conduit. Or maybe there are already more than one circuit worth of conductors in there? Could be two "hots" and one shared neutral, which would give you two circuits.
