N4HHE
LOL. "Neck snapping"? "Slammed"? Sounds like using the S cruise control is like the Space Mountain ride at Disneyland. I find the sensation of changing 1MPH barely perceptible and the regen upon disengagement gradual.
+1 MPH jerks like a bad manual shift or a hotrod automatic transmission. Tap the +1 CC while watching the power meter: 15-20 kW jumps to 80 kW then falls below 10 before stabilizing back where it was before. No one who has studied control theory would find that oscillation acceptable.
+5 MPH is much smoother now than +1 MPH.
- - - Updated - - -
The +1 and +5 trim works for me. However, when TACC disengage, MS should simply cruise down by removing power to the motor like an ICE, and without regen. Regen may light the brake light and annoy the car following you. It will be up to the driver to decide whether application of brake is needed or not. When driver do decide to apply brake, then both regen and brake may be applied.
Yes, +1 and +5 works but +1 isn't up to the expectations of a Honda or Toyota, much less a Tesla.
Agree that disengaging the CC should not result in aggressive regeneration unless the driver applies the brake.
