No, non-export simply means your system is designed that as a net it doesn't export to the grid, except for very short transients (the length allowed will be defined by your local utility). However, your inverter can still be grid tied (and thus still have a grid connection).
PG&E has an explanation as an example:
Non-Export
Off-grid means the solar system is never connected to the grid
at any point in time. That means even if you use a grid-tie inverter (that you can keep "awake" by using a compatible battery inverter), it must be isolated from the grid, such that at no point in time is there ever a connection to the grid. There are multiple ways to achieve this:
1) The solar system powers loads (which can be a subset of your total loads) that are disconnected from the grid completely. This is the typical definition of off grid and what off-grid inverters are for.
2) Have a manual transfer switch (like the ones you use for generators) to switch to grid power manually when your solar/battery system stops generating power.
3) Have an automatic transfer switch (ATS) that automatically switches the loads to the grid when your solar/battery system stops generating power.
4) Have a hybrid inverter that has a built in ATS that can achieve this function.
The goal is simply to move your solar off-grid (making NEM completely irrelevant), you don't need to move your whole house off-grid.
I have a Fronius Primo grid-tie inverter myself, and it's compatible with Victron Quattro or MultiPlus inverters, such that I can not only add low voltage energy storage to my system, it also has a built in ATS that allows it to function as a "microgrid" which is backed up by either the grid or a generator.
MicroGrid & backup systems for grid independence
In this configuration, at no point is the grid tie inverter connected to the grid, the grid only functions as a backup when the batteries are low.
