You're not going to damage the battery as long as you keep it between 20% and 80%.If I had a longer commute I think I wouldn’t care that much. But I think I have an usually short commute. And that can be hard even on an ICE vehicle as well.
I could go no charge all week and wait until I travel to the cabin where I will always stop at a supercharger. But I wasn’t sure if that would be hard on the battery. By not doing the recommended plug in every night.
I’m also curious at temperature points this could matter. If it’s only when say it’s below 10F I’ll either skip charging nightly or eat the execessive reheating to charge a small amount of usage daily. Long spells below 10F are not to common. So either way would be fine. But months below 32F are common.
Is there a way to tell if it’s doing more heating than charging. Low mile per hour charge rate?
I think you are thinking about this too much. A short commute will have no impact other than you will not have full region and full power. And you will use more energy in the winter with or without pre-heat.
Are you concerned about the impact on the battery or the amount of energy used?
The battery will last longer stored at cooler temps. You car is going to be sitting most of the time so your climate is good for the battery.
The cold does impose some operating limits on the battery. The Tesla BMS will take care of these limits. The main downside is lack of regen. Preheating the cabin and battery will avoid some of this but not all.
Here is a link with a table for general degradation of LI versus temp. (Not specific to Tesla but shows the trend.) Again, with cold there is less battery degradation but it does impose some operating limits on the battery.
How to Prolong Lithium-based Batteries - Battery University
I'm worried if I follow the manual (to keep your Tesla Plugged in when not in use) it will cost me a small fortune because I'll be heating way more than charging.
I'm worried if I follow the manual (to keep your Tesla Plugged in when not in use) it will cost me a small fortune because I'll be heating way more than charging. I think I do need to think about it and do what some folks recommended and ignore the recommendation and accrue more usage before plugging in when it's cold out.
I also don't have experience of knowing what those thresholds are to stop plugging in nightly. Below 50F, Below 32F, Below 0F?
It was 28F last night. Garage was probably low 40's. It did not put up the "No Regen Warning" but I believe it was in partial regeneration.
And never made it to full regeneration. I still plugged in and it was at full charge rate (miles per hour) after about 5 minutes.
I still got close to 260 wh/mi (with heat going). So it's still doing pretty good.
Model 3 doesn't have a range mode selection.Assuming the M3 is like the MS, you may want to use "Range Mode" in cold weather (< freezing) because that avoids the car trying to heat the battery. In 5 minutes it is just a waste of energy, so you may as well turn it off.
Setting it to charge before I leave I think would use more total energy (more waste) than anything. The car will naturally be warmest when I get home in the evening. The days are warmer and it has been driven (albeit often short drive) with heater commonly on.
Waiting for that little bit of heat to cool off, and often a huge drop in temps overnight. I’ll spend way more on heating than charging.
Yes, it definitely does, depending on temperature level. When the cells are really cold, it would be actually damaging to charge them at all, so it must warm them up at least some, before it can do any charging, and then it gradually increases the amount of current you can give them as the temperatures keep rising.Does the car warm the battery just to charge on a 40A home charger? I thought it only warmed it for supercharging. I'm probably wrong, but surprised if it does warm it for slower charging like that.
That's definitely not the reason people freak out over it. It's just the thinking of: "Here's how it's supposed to act, and it's not doing that. Something's wrong!"extra few dollars for electricity here and there should not matter to any of us.
I think that we should all worry a bit less about this stuff. The only time you should give this any thought is if you part outside in -30C for days or something like that. I live in Utah, park in an insulated garage that stays at 5C when it is -15C outside and I charge, preheat, and drive without giving it all much thought whatsoever. Even if I parked outside in -15C I would do the same. If the charge is low when I get home I plug it in. Otherwise I just leave it. Even if regen is limited I still have brakes I can use to stop the car.
We all paid over 50k for our cars, extra few dollars for electricity here and there should not matter to any of us.
It will still cost half of an ice car in consumption. Leave it plugged in. Charge to 80-90%.
Also, preheat the car for a half hour before leaving. Enjoy.
