SwedishAdvocate
These conversations do nothing to help Tesla.
How can you be so sure?
- - - Updated - - -
And also: Why wouldn’t they?
Well, my comment was directed at the original bashing tone that was coming out at the start of this thread, that has since been edited/toned down. Discussing with calm is always good though.
I don't think the jury has settled the issue yet - still some debate going back and forth... As to whether its man caused, partial mix, or if its the normal ebb and flow of earth cycles (and man is unable to influence it). But what I do know, is that we can act prudently when and where we can.
"…] we’ve had already in the New York region 10—nine to 10 inches of sea-level rise over the last 100 years […"
Source (includes transcript):
Cynthia Rosenzweig, senior research scientist at NASA Goddard Institute for Space Studies, where she heads the Climate Impacts Group.
NOVEMBER 1, 2012
A Crisis Foretold: Studies Warned New York Infrastructure Critically Threatened by Climate Change
All the IPCC predictions are based on models that can't even replicate accurately the climate of the last 20 years.
They ignore water vapor because they are not sure if its a plus or a minus.
And we are supposed to bank our future predictions of a hundred years from now and trillions of dollars on that?
Time to get real and not taken.
Climate change happened before Homo sapiens and will continue after them. Greenland was without ice before cars and glaciers covered most of North America and Europe. Climate change is a constant on earth.
Who are we to determine that TODAY'S climate is the most ideal climate?
Kaviball,
I agree with you in part, in that I don't trust computer modeling. I've done computer modeling in the past - on something not nearly as complex as the climate - and you have to be very careful when you extrapolate beyond what you can empirically validate.
Unfortunately modeling is just a tiny part of the evidence. The basic physics of the situation were worked out in 1890, and by now are pretty well understood. CO2 does trap heat, as does methane.
Saying the amount of CO2 emitted is small compared to natural cycles misses the point - the imbalance accumulates over time and we can directly measure that it is indeed increasing.
You are correct that the Earth's climate varies over time. It is largely driven by variations in the Earth's orbital eccentricity. Unfortunately the current warming trend is not explained by that.
The Earth will survive the changes; the question is whether we will. It's apparent that the current conditions are a pretty ideal climate for us humans, in that large areas of the world are habitable and suitable to agriculture. It would be wise for our own good not to push it away from that state.
And here are a few other credible sources IMHO (The one with video includes transcript):
James Hansen: Why I must speak out about climate change | Video on TED.com
Climate change is here and worse than we thought - The Washington Post
Arctic expert predicts final collapse of sea ice within four years | Environment | guardian.co.uk
When you ask who are we to determine that Today's climate is most ideal, make sure you understand the ramifications. As the world heats up just a couple of degrees sea levels rise by both thermal expansion and glacier melting. And while we have only seen a modest 8" of sea level rise we are on track for 3' of rise by 2100. We saw the devastation by huricane Sandy. From all I know it would have been much worse with 3 more feet of water. Millions live on or near the coasts and it will be VERY expensive to build dikes around all areas that need it. So yes if you are a farmer in Siberia or Canada or even North Dakota then yes Global warming will bring benifits. But if you live near a coast or in a warmer climate like Australia (who reciently saw a country AVERAGE of more than 114 degrees) then global warming will bring about huge challenges and costs.
Through-out most of Earth's history Florida was underwater as sea levels were some 100' higher. That is not a change I want to see.
Sea levels haven't risen near as much as predicted in early 2000, late nineties. Yet, the same models are used to predict what things will be like 100 years from now.
While the nature of the climate change cycle in general may be out of our control, do we really need to be pouring gas on the fire if we can avoid it?We can't stop climate. We can't stop the climate doing from what it has been doing for billion of years. We are experiencing natural heating and cooling cycles
I would highly recommend you check out the video I linked above.
The sea level rise model is a orthogonal to the climate change model and every number comes with a certainty level. The 2100 sea level prediction comes with a 50% certainty.
First of all, we aren't trying to stop the climate, we are trying to stop our contribution to the climate. Yes, we are experiencing natural heating and cooling cycles, but our activities also contribute to those cycles in measurable ways. We are 90% certain the current warming is caused by human produced greenhouse gases.We can't stop climate. We can't stop the climate doing from what it has been doing for billion of years. We are experiencing natural heating and cooling cycles.
It's not an either or scenario. First of all, the scientific community already has clear agreement that we ARE affecting the climate with our activities. The variance is in the magnitude (as mentioned above). The suggestions for change involves reductions in GHG emissions AND adaptation to the effects. Either one alone is likely not going to be enough.We can either make futile attempts to "stop" the climate from changing and waste trillions and trillions of dollars doing so, or we start thinking about how we will adapt.
