Indeed the option to explicitly set a limit of 80% is what's new on the 15's - and that's what I have done. Also per my posts above, if this requires a second charge later in the day - that's better than starting with 100%.
Nothing - it is the same as in Pro 15, when it comes to battery health and charging. What has changed overall is you have an option of 80% limit. Optimised charging on iPhone means learns from the charging routines and wait to finish past 80%.View attachment 994618
That's what it says on an iPhone 15 Pro. Never had an iPhone before, so not sure what has changed...
Off topic but ... what software do/did you use to put a limit on MacBook charging?Not something I ever worried and had issue with iPhones in the many years since they are a different usage case to let say my MacBook which is 99% of the time plugged in but I use 3rd party software to limit it to 70% charge.
AldenteOff topic but ... what software do/did you use to put a limit on MacBook charging?
Off topic, but I meant it’s healthier to start off your day with your phone charged at 80%. (even if it means having to top up during the day) than to start off with with 100% and not charge during the day.Im sorry but i dont get it...why would you start a charge with already 100% ?
For the record Samsung have had this feature for a couple of years and retro added it to some older models at the same time. Its only software after all. But they keep it pretty well hidden. Almost like they don't want you to use it.Indeed the option to explicitly set a limit of 80% is what's new on the 15's - and that's what I have done. Also per my posts above, if this requires a second charge later in the day - that's better than starting with 100%.
Did you mean it is Elon’s car - the first Roadster? That was the only Tesla that I can think of that is 19 years old!19 year old car :/
I agree. More over, what is the actual battery capacity I have? is it 80, 79 or 76 kwh? if you add this number as original capacity, then the drop rate changes as well :/It kind of shows why these things are nothing more than a rough idea - 10k miles ago you had a reading where the battery had half the loss you do today and better than a reading at around 16k miles. When you first got it, the battery even improved over the first 10k miles,
You can see a general trend and thats useful, but I'd have thought what we'd ideally need is benchmarking against cars with similar mileage if nothing else. Is 6.7% good or bad for a car approach 40k miles?
1.9 fixedDid you mean it is Elon’s car - the first Roadster? That was the only Tesla that I can think of that is 19 years old!
True, but given his interest for numbers and modesty , I thought he has put up the data in some kind of forum as he does not like marketing that much!I think that one is in orbit.
