I leave this on my dash with the paper clip indicating the time I can be unplugged. I also have my phone number shown. Eliminates all the confusion:
I like that! Very smart.
If I desperately need a charge and the only spot available is occupied by a plug-in hybrid that doesn't really need the electricity, I would have no inhibition unplugging that person. Without that charge, I can't go anywhere. The plug-in hybrid, by contrast, can still go anywhere. If the plug-in hybrid driver had an empty gas tank, or only 1-2 gallons in a much larger tank, whose responsibility is that?
That's correct. The adapter stays locked into the Model S but someone can disconnect power by unlatching the J1772 handle.
I'm inclined to agree, but in my case I think it would be with great hesitation. I'd do everything to try and find the owner first. Normally, I don't bother with "opportunity charging" but I have seen Volts (and other PHEVs) plugged in at hotels and such overnight which is, IMHO, bad form.
I charge with J1772 three to four times a week as my primary charging method. Mine won't unlock the adapter from the port unless the car is unlocked. I had an issue with my key for awhile that prevented it from auto-unlocking, and I always had to remember to push the unlock button to get my adapter out after hitting the J1772 button.I'll have to test this, but I believe I heard that the Model S will momentarily unlock then re-lock the port when you press the J1772's handle and that the adapter may come out of the car even though the car is locked. I've heard of owners coming back to find their adapter placed up on the bottom edge of the windshield. Not sure if later firmware has corrected this.
I own a volt and a model S. I rarely use public charging for the volt. 15k miles, over 99% on electric. The volt is no less an EV than the model S. A BEV owner has no more right to use public charging than a PHEV owner. A BEV owner doesn't get priority and doesn't have any excuse for unplugging another EV of any type. Just because a PHEV can use gas doesn't mean that owner should be forced to do so because of another EV owner. For one, it's more expensive. By prematurely unplugging another owner, you are increasing their costs. Are you prepared to reimburse them because you felt you were somehow more entitled?
The real problem is that people are not considerate to others. Move your car as soon as it's done charging. At a minimum, leave contact information or use one of the apps that enables blind communication between owners.
From a technology perspective, I'm eager to see multi-head EVSEs make their way into the field. One circuit, 3-4 heads. Let the EVSE automatically transfer between cars on a first come first serve basis.
See, I disagree--a PHEV *is* less of an EV than a BEV, in the sense that it is not constrained by the same limitations as a BEV. If you can't charge a PHEV, you can drive on gas. That's the whole reason (and the only reason) to buy one; it makes the lack of charging options (or the failure to get a full charge) an inconvenience, rather than an emergency.
As for increases in costs? Well, yeah. That's a pain. But you are talking about an absolute maximum of, what, $4 (assuming you got zero charge and had to drive 40 miles on gas rather than battery)? Realistically, much less? I suppose any involuntary imposition of costs is rude, but $4 vs not being able to get home? That's a big difference.
And driving around in a Volt with only a gallon of gas to save weight is a bit pointless. You're saving maybe 20 or 30 lbs, when JB and Elon the other day noted that even a couple hundred lbs only have a negligible effect on efficiency. And in exchange you are completely gutting the whole raison d'être of the Volt, which is to provide a backup in emergencies.
Think about it this way--if you were driving a PHEV and you pulled up to a public charger at the same time as a Leaf or Model S who was far from home and needed a charge to get there, would you let them go ahead of you? I think (hope?) that everyone on this board would. The situation we are talking about really isn't that different.
I think people need to look at this from another perspective.
Say you need a charge and you notice a Leaf has been there for 1 hour. Since he has 20 miles range now and there is another charger within 20 miles, you feel your can unplugging him to charge your car, since he can "make it to the next charger"? Sure it's in convent and may cost him time, but hey, you need a charge and you feel it's your right to unplug people who don't "need" to be charging right then.
How would you feel someone did that to you? Your would go probably go ballistic call the other driver inconsiderate, post a rant on TMC, etc.
No one has the right to unplug another car without permission, unless the car is done charging. You can make excuses to justify your actions, but they are still wrong.
Beside being wrong on principle, you may also be stealing money from him. Many chargers charge a base fee + hourly rate, and most charge a whole hour increment. if he paid $4.95 + $1 an hour and you unplug him a 1/2 hour in. You basically stole $5.49 from him. Even if it's just a $2 an hour flat rate, unless you unplug in at 59 minutes into an hour, you are still stealing from him up to $1.99. Yeah it's just a few $, and I guess some people feel fine just taking money from people because they need it now.
b) unplugging the PHEV, I'd do the latter. S/he has a choice. I don't.
So irritating.
What about YOUR responsibility to get to you destination without unplugging anyone else? Why should the PHEV vehicles owners bare the cost of your own irresponsibility?
That's your problem, not anyone else's.
Like I said, I see your point, but I disagree. A PHEV has a whole separate fuel system for a reason. I wouldn't do it unless I absolutely had to, but if it came down to a) sitting there waiting some indeterminate period of time (hours?) for the PHEV driver to come back so that I can charge and get home, or b) unplugging the PHEV, I'd do the latter. S/he has a choice. I don't.
And while we are on the subject, can I just reiterate exactly how much it pisses me off to see Volts and PHEV Priuses plugged in at Dulles airport? Those things are probably going to be done charging by the time the owner boards his or her flight, yet they are going to blocking the charger the entire time the owner is gone. And if you show up at the airport in your Leaf/FFE/other BEV, you are just screwed.
So irritating.
You had a choice, and decided not to buy a range extended EV. You do not know if they have a choice or not, unless you can ready their gas gauge. and you are costing the the price of the charge and the gas needed to get home.Like I said, I see your point, but I disagree. A PHEV has a whole separate fuel system for a reason. I wouldn't do it unless I absolutely had to, but if it came down to a) sitting there waiting some indeterminate period of time (hours?) for the PHEV driver to come back so that I can charge and get home, or b) unplugging the PHEV, I'd do the latter. S/he has a choice. I don't.
So irritating.
Are you alright stealing from a grocery store if your are hungry and have no money? How about stealing gas from a gas station, to get home? It's just a few dollars and the store/station will not miss it. Is it okay to mug someone on the street to get gas money to keep from being stranger?
What on earth does theft have to do with this discussion? Unplugging a car charger is not equivalent to theft on any level. This is a very bad analogy.
True, it may not technically theft, but the effect is the same for person getting unplugged. That person is still out $5 or whatever and does not have a charge they paid for.It's not theft (or conversion). In some of the scenarios liuping sketched out it might be akin to tortious interference with contract, but it's not theft. You may be preventing someone from getting what they paid for, but you aren't taking anything from them.
I've never been in this situation, and hope I never will be. There's nothing about my driving style that makes it likely I will be, other than that I drive a BEV and occasionally go beyond the range of my home charger and plan to rely on public chargers to get me home. If that means I've bought the wrong car, well, then--we all have. We should all have bought Volts so we don't have to worry about it.
Most Chargers charge by the hour. If someone unplugs them early, the cost of up to an hour is lost.
Some chargers have a plug in fee + cost for electricity used. If someone unplugs a car early, the owner is out the plug in fee (other at high as $4.95)
Even if it's a free charger, forcing them to use gas, when they did not want or need to, that is $4 a gallon.
Unplugging someone is costing them money without their permision. I stand by my (admittedly extreme) examples.
