One approach might be to talk about what the very long term solution is, and present what is to be done now as a stepping-stone to that distant future.
If electric cars ultimately become a substantial proportion of the fleet, then the expectation must be that every parking space needs a charging point. However, this doesn't mean that each building needs an enormous supply of power: most of those parking spaces will either be empty or the cars in them already fully charged. The average car in the UK does only 23 miles per day (I suspect the figure for Hong Kong would be lower), so if they were all Model S (300Wh/mile), each car would need 23 * 0.3 = 6.9kWh per day on average to keep it charged - just an average of one hour per day on the charger. So the building with enough spare power to supply 4 charging points at 32A (approx 7kW) each would actually have enough power to supply the average needs of 24 * 4 = nearly 100 cars. This is slightly optimistic as there will obviously be surges of demand on particular days - but the more cars you have, the more chance you have to smooth out these statistical variations, and 100 is quite a large number. The numbers probably don't work so well in the early stages, as the EV early adopters are likely to do higher-than-average mileage.
Obviously it would be hugely inconvenient to manually shuffle those 100 cars through 4 charging spots, but this problem is easily solved: fit a 'smart' EVSE to every parking bay, with software that shares out the available power between the cars that are requesting charging. The existing communication between EVSE and car allows the EVSE to limit the current or shut it off altogether, so there's no change needed in any of the cars - just smarter software in the EVSE (and in particular, communications links between them). Once you have these comms links, it gets even better: rather than just limiting the total power to the amount that the building can spare over and above existing loads, the car charging can be linked to the building's overall power consumption and for example when power taken by aircon reduces at night time, increased power can be diverted to car charging. So the example above of 180 units with enough spare power for 4 simultaneous 30A EVSE could possibly in fact support every one of those 180 spaces having an EV, without needing any increase in the supply to the site!
Here's a video about an experiment in the UK where they explored what would happen if every house in a suburban street had an EV - solving the problem in just this way with smart EVSEs at each house which could be switched so as to balance the total load on the substation feeding the area.
http://www.youtube.com/watch?v=jaWruGLgLlE This is actually a harder problem than a large building with a carpark - they had to use radio to link the EVSE in the various houses together, wheras in a carpark they could just be wired.
So the sensible progression would be something like:
- Install basic EVSE as required by the first few users, up to the limit of available spare power (4 in the example above). Preferably, reassign parking spaces to keep the EV owners together to ease future expansion.
- As demand grows, upgrade to smart EVSE that can share the same amount of power over say 10 or 12 spaces.
- As demand grows further, install more banks of 10/12 spaces but with overall demand management so that full load can only be drawn for charging when loads elsewhere in the building are reduced (typically at night).
