That’s helpful. I was planning to use CoS on the weekends and had the impression that turning CoS off and on was a pain.
Am I right in reading that turning CoS off and on again is a simple toggle in the app?
You mean charge limit for the car?
On app on phone I seem to have lost the 3 dots and can not coax them back. I am sure they were there yesterday.Yep. See below.
Tap the 3 dots in the upper right of the charging panel. Tap on the “Charge on Solar” popup that appears. Then the CoS settings window appears, there is a toggle there to turn “Charge on Solar” off.
I wish they would make it available as a minimum charging limit by defaultYep. With CoS on, you can set an upper limit of 30% SoC for your car charging from the grid
Yes but can you then turn it back on? When I tried doing that, I lost all dots and all ability to turn it back on.Tap the 3 dots in the upper right of the charging panel. Tap on the “Charge on Solar” popup that appears. Then the CoS settings window appears, there is a toggle there to turn “Charge on Solar” off.
Just checked also lost them on Ipad app.
I think I read somewhere that it drops to single phase charging to achieve this degree of control at lower levels of available solar.OK, ignore the above post . I turned on Charge on Solar this morning to try it out, but only after my PW2 was full.
- Interesting you can now set a charge limit lower than 50% to charge from “any source” - the minimum is 30%. Previously it was not possible to set a charge limit of less than 50%.
- Scheduled charging (e.g. overnight) will still happen if the car’s SoC is below the threshold set above after “Charge on Solar” has finished for the day. Charging from the grid would stop once the “charge from any source” threshold is reached.
- It seems it is easy to turn Charge on Solar off - tap the 3 dots in the charging section of the App to open up the Charge on Solar settings, and there is a toggle there to turn it off.
- Charging rate goes as low as 1.2 kW (5A single phase) but I have 3 phase, so charging actually goes as low as 1.7A per phase but the current setting slider in the Charging section of the App still shows 5A as the minimum charge rate, even when it has gone below that and is displaying that lower Amp value in the data bar.
- I still don’t want my solar charging my car in priority to the PW2, so I expect I’ll be turning CoS off after it has finished today, and only turn it on again manually when my PW2 is full and the car needs charging. This needs to be fixed.
I still haven't got charge on solar working. The only thing I can thick of is that it might be WiFi. Where my car is parked it has trouble connecting to my house wifi. It often drops back to its mobile connection which works fine for everything including charge HQ. If it won't connect for a software update I use my phone to share my home internet. My wall connector and Powerwall are both fine with the wifi. Is the car required to be on the same wifi network as the Powerwall or can control happen over its cellular connection? This should be listed as a requirement on the Tesla website if it is.
No, I cannot see the controls. My phone is paired with the Powerwall. I've got the correct software versions on everything but have never seen the controls. I've logged out and in many times and have done a complete reinstall once, which required making a new phone key for the car and pairing with the Powerwall again.I assume you can see the Charge on Solar controls in the Tesla App? You need to pair your phone with the PW2 before it will appear.
The Tesla Fleet API, which is used to actually implement the CoS function, is network connectivity agnostic. As long as the car has an IP address and can be woken up, it should work.
Your version makes more sense as long as the charger in the car can do it.Hmm… that’s not what I saw. The charging info bar in the App showed charging went below 5 amps per phase. There’s a little ‘3’ in a circle that appears in the info bar to indicate when charging is on 3-phase AC. I’ll take a screenshot next time.
However, it rapidly became apparent that since my switchboard is wired such that the Telsa charging cannot be seen by the Powerwall (to prevent dumping the Powerwall into the Tesla, rather than charging from the grid at the overnight super off-peak rate), the Tesla Charge on Solar control is apparenly oblivious to the actual Tesla charging load.
Yes. That’s also what I saw today. Three phase remained. Here’s a screen shot of the Wall Monitor app when the car was charging at 1.6kW at three phase off Charge On Solar. You can see that each of the phases is at 500+kW.The charging info bar in the App showed charging went below 5 amps per phase. There’s a little ‘3’ in a circle that appears in the info bar to indicate when charging is on 3-phase AC. I’ll take a screenshot next time.
