I have an iPhone 4S which plays through the old 30-pin connector to the JVC when the "iPod" source is selected. At an earlier time this did not work; the JVC would just say "Reading..." forever, and cause the phone to be locked to the JVC for control so its own interface did not work. Then a new iOS version fixed that problem, so now the iPhone's UI works and the JVC does display the song info.
During the earlier time, what I did was to change a setting in the JVC so the iPod source selection was changed to "External audio". That way it did not try to use iPod control and just took the analog audio that goes over the iPod connector. Doing that configuration change requires standing on your head and rubbing your tummy at the same time (that is, it requires navigating through some contorted sequence of JVC menus that I can look up for you if needed).
Is there a lightning-to-old-iPod adapter cable that gives the full iPod functionality?
