TBH that sounds more like a bureaucratic sabre rattling statement. SpaceX (and Tesla) have gotten similar statements from regulatory agencies in the past. The "it isn't official, until we make it official" regulatory statement.
SpaceX failed at recovering their cargo capsule when CSR-7 failed simply because they hadn't programmed the capsule to go through the landing procedure should it encounter an anomaly and find itself separated from the booster. So BO has that one over SpaceX. SpaceX did learn some good lessons from that mistake and their new cargo system should attempt a proper water landing if an anomaly occurs..
That... is true...A reasonable rant. I just wanted to give credit where it was due. We often take shots at BO since they still haven't gotten to orbit yet. In this instance though, they successfully recovered the payload and capsule from a failing booster. Which SpaceX did fail to do when it happened to them. SpaceX learned important lessons from that and, there is no doubt in my mind, they are a better company recovering from their failures. The incredible numbers prove that: As of today, SpaceX's 188th successful orbital launch within the Falcon program in a row and the 107th landing of a Falcon booster in a row since their last failures.
During a panel at the Satellite 2023 conference March 15, Tory Bruno, chief executive of ULA, said he was still confident that Vulcan would be ready for launch in May, based on tests on the pad and qualification tests of the vehicle’s BE-4 engines.
...shipping the engines to ULA’s factory in Decatur, AL after final acceptance testing.
Dozens of these engines are now in production...
...Development of this new engine is complete...
Interesting you say that... I had a similar thought. "Fatigue" implies something over some duration... but I wondered if that duration did not necessarily have to span more than one flight...They uses term "structural fatigue" that means many cycles of thermal or other stresses? (-> Multiple flights or engine firings) If upgrade was only in this flight, they would said something like "thermal deformation" or "temperature exceeded tolerances". Can any structure or material engineer confirm this?
Yeah, sounds that way:I believe the article said that BO had upgraded/improved their engine in some way which increased the heat and allowed for the burn through.
It's low cycles of operation, but the nozzle experiences high levels of acoustic/ pressure variation/ oscillation in use (especially if throttling), so a single mission could have fatigue vs ordinary overload.They uses term "structural fatigue" that means many cycles of thermal or other stresses? (-> Multiple flights or engine firings) If upgrade was only in this flight, they would said something like "thermal deformation" or "temperature exceeded tolerances". Can any structure or material engineer confirm this?
Aided by onboard video and telemetry, flight hardware recovered from the field, and the work of Blue Origin’s materials labs and test facilities, the MIT determined the direct cause of the mishap to be a structural fatigue failure of the BE-3PM engine nozzle during powered flight. The structural fatigue was caused by operational temperatures that exceeded the expected and analyzed values of the nozzle material. Testing of the BE-3PM engine began immediately following the mishap and established that the flight configuration of the nozzle operated at hotter temperatures than previous design configurations. Forensic evaluation of the recovered nozzle fragments also showed clear evidence of thermal damage and hot streaks resulting from increased operating temperatures. The fatigue location on the flight nozzle is aligned with a persistent hot streak identified during the investigation.
Yeah, that interpretation occurred to me as well, but that BE-4 page, in the body of the paragraph I pasted, says right after that: "BE-4 is currently undergoing full-scale engine development testing..." which tends to imply they aren't simply moving production towards full-rate, but rather moving towards production.Note the words “full rate production”. I think the BE-4 web page is simply saying that BO is ramping up engine production to the planned “full rate”, whatever that may be.
Or the web page is just out of date.
Qualification tests follow and are conducted on flight-quality hardware at load levels and for durations that usually exceed flight conditions to demonstrate that all structural design requirements have been achieved. Acceptance tests are the final series of tests conducted in a typical hardware program.
From other posts on the web (and my vague recollection) :Yeah, that interpretation occurred to me as well, but that BE-4 page, in the body of the paragraph I pasted, says right after that: "BE-4 is currently undergoing full-scale engine development testing..." which tends to imply they aren't simply moving production towards full-rate, but rather moving towards production.
Also, regarding testing, NASA states:
So my next question is does one actually launch with engines that have gone through qualification testing? Ostensibly they have exceeded flight conditions.... but not necessarily engine specifications? Table seems to make a distinction between "Flight Quality" and "Flight" hardware,
Bruno says the 2 delivered to ULA are going through Quality Testing, yet he had said they were only going to be shipped after final acceptance testing... implying that acceptance testing happened at BO's facilities... perhaps in conjunction with ULA personnel? Does a customer do both types of testing as well?
Something seems odd about how these are being presented.
So it seems, that while there may be some overlap, Qualification Testing is a phase that completes prior to Acceptance Testing:From other posts on the web (and my vague recollection) :
BO shipped ULA engines that had undergone acceptance testing. In parallel, BO performed qualification testing on separate units. Assuming the QT passed without engine mods, ULA's engines were good to go.
Right, that's a program timeline, not a per-engine testing regiment.So it seems, that while there may be some overlap, Qualification Testing is a phase that completes prior to Acceptance Testing:
So the pair that shipped to ULA, if they had already undergone acceptance testing, that implies qualifications testing completed prior right?
I guess the question becomes: are Qualification and Acceptance testing done for each article? Or is the design Qualification tested and then individual units are each accptance tested?
Otherwise from your twitter link that the engines ULA had did not undergo qualification testing, and were shipped to ULA to test/accept. Which if the qualification step is only for the program, might make sense...
Normally, the engine family gets qualification tested to validate the design. After that, individual units get acceptance tested to validate manufacturing/ their build out.
In the case of ULA's engines, they accelerated timing by doing acceptance testing and shipping those engines, then they performed the qualification testing. Assuming qual passed, there is no difference from the normal flow. If qual had failed, it would gave invalidated the acceptance testing and the engines would have been reworked and retested.
While I wouldn't rely on web pages for up to date details, as of Feb 23, BE-4 had NOT finished qualification testing.Ok, thanks.. that validates what I thought must be the case.
Then in which case it moves back to BO's stating that "BE-4 is currently undergoing full-scale engine development " that's the strange statement about the engine status.
And the first two Vulcan launches are also qualification flights for carrying national security assets.It’s worth noting that BE4 will need to go through two qual campaigns, one for the Vulcan mission and one for the much more rigorous NG mission.
So it's undergoing development testing, qualification testing, AND acceptance testing, simultaneously?While I wouldn't rely on web pages for up to date details, as of Feb 23, BE-4 had NOT finished qualification testing.
So, "BE-4 is currently undergoing full-scale engine development testing at our facilities in Van Horn, Texas." is accurate.
